Ok, sorry if that wasn’t clear, I am dealing with a 12″ 45rpm black record. When I press start the TT is in 33rpm mode two possibilites:
- If i do nothing the arm goes past the edge then switching to 45RPM say halfway through then continues to the end and returns to the resting position. The arm does not drop
- I have tried hitting the 45rpm button immediately after start and it does the same thing.
I am able to stop the arm and move it in whatever direction I need but the arm will not drop as if it is not seeing the record
I made a small “boot” to put over the optical sensor and it works well but does drop the needle a smidge early so you have to nudge it slightly with the button. It will return to the resting position once the end of the recording is reached correctly.
