david.jones
Forum Replies Created
  • in reply to: Beocenter 7007 – adjust amp voltage trimmer resistors #64026
    david.jones
    Hi Filip, I now have another Beocenter 7007 with a similar problem and I wish to change the trimpots you mentioned above. I can’t find the specs for these. Could you advise where I might purchase these please?
    Thanks in advance, David
    in reply to: Beocenter 7007 – adjust amp voltage trimmer resistors #62964
    david.jones
    Filip, many thanks for this, very helpful, all working now. I would not have known where the resistors were for meter probe placement. I hope this will help others as apparently this is quite a common fault.
    Regards,
    Nick
