Christian
Forum Replies Created
  • in reply to: Low-Budget Multiroom Setup for Ceiling Speakers #64346
    Christian
    Thanks a lot for all the input. I have now several of the mentioned products on my Watchlist and are waiting for a good deal. Will come back once everything is in place and working.
    in reply to: Low-Budget Multiroom Setup for Ceiling Speakers #64015
    Christian
    Wow, thanks a lot for the information. Very appreciated. So if I understand correct I can choose from the following components:
    Main Component:
    • Beosound Essence Mk2 (cheap)
    • BeoSound Core (medium)
    • Beoconnect Core (expensive)
    Amplifier:
    • Beolink Passice (cheap)
    • BeoAmp 2 (medium)
    Speakers:
    • Every cheap ceiling speaker will do
    Correct?
    If this assumption is correct, two more questions:
    1. Are there any active ceiling speakers you are aware of, so that I can skip the Amplifier? My understanding is, no, as they would also need to speak “Powerlink”
    2. If I have multiple Speakers (say 2 as stereo pair in the kitchen, maybe 1 in the guest toilette and maybe 2 in the dining room, I would need several “main components”, see above. There is no solution where I can have only one “main component” like a Beoconnect Core and drive 3 areas independently, correct?
    in reply to: Low-Budget Multiroom Setup for Ceiling Speakers #63988
    Christian
    Thanks for the fast response. So I understand you suggest the Beoconnect Core (new). I mentioned the BeoSound Core (legacy). Will the BeoSound Core be sufficient or is the Beoconnect Core needed? This first one is available for around 300-400 € at eBay where the later is > 1.000 €. Furthermore the BeoAmp 2 is also very expensive, more like 650 €. Therefore I tend for a 3rd party solution as it should be a budget solution. Its just for background music.
    You mentioned Adapter Cables to run 3rd party Amplifier and Speakers. What would I need here?
