Chris Barker
Forum Replies Created
  • in reply to: Beo 4 remote not working with Beosound Century #70842
    Chris Barker
    Hello All – thanks for the reply – I’m not getting notifications, hence the delay in replying
    Another q – if the capacitors on the IR unit were duff – would the Century on flash 1 when trying to be set up? – just trying to confirm I undertook some reasonable soldering!
    re the picture – it’s the left one of the 5
    Hope that helps?
    Cheers
    Chris
    in reply to: Beo 4 remote not working with Beosound Century #70792
    Chris Barker
    Cheers  -yes – have done that – still no joy. – the display reverts to standard once you press 1 – should it flash?
