Thanks for your answer .
Am I correct in assuming the Beolab 2 can only connect to the Theatre bar through cables ?
if so , do you think there’d be a sonic mismatch between having the Beolab2s connected to the bar via wires and having the Beolab 11s used as a substitute for a bass shaker – I.e placing the beolab11s right behind the seating to make the seating shake a little for that near 4D effect ?
thanks
