b-a-r-t
Forum Replies Created
  • in reply to: Beovox C40 filter capacitors #52466
    b-a-r-t
    So I replaced the capacitors with bipolair ones.
    The sound has improved dramatically!
    Thanks Martin.
    Regards,
    Bart
    in reply to: Beovox C40 filter capacitors #52465
    b-a-r-t
    Ok, I ordered new ones, let’s see if we can get these to sound good ?
    Thanks Martin
    Regards, Bart
    in reply to: Beovox C40 filter capacitors #52463
    b-a-r-t
    They are definitely not bipolar Martin, in the pic you can clearly see the plus indicating polarity, and if you google these Roederstein you find they are regular. So, are these the original ones? I presume they are. Could replacing them make them sound good? Regards, Bart
