alexander.luft
Forum Replies Created
  • in reply to: Beovision 7-40 MkII Masterpin / Pincode entry problem #70651
    Similar problem.
    solved by using a different beo4
    There are different versions of the beo4 remote.
    be sure yours has a DVD button on row two from the top.
    Favourite Product: Beosound 9000
    in reply to: Beolab 7.2 no sound #69467
    There is reference to a fuse in the Beolab manual.
    When power plugged in, what colour is the light by the power input?  Its hidden under a rubber bung.
