Home › Forums › General Discussion & Questions › General Discussion & Questions › WiSA vs Digital Powerlink
- This topic has 5 replies, 3 voices, and was last updated 7 months ago by
Razlaw.
10 August 2025 at 14:25 #68702
Razlaw
BRONZE MemberI have a Theatre with 28s in the front and 9s in the rear. I am thinking of replacing the 9s with 8s.
I see the 8s, just as the 28s, can be connected by both WiSA and digital power link.
Is one preferred over the other? Do they function any differently in every day use once connected and set up?
Thanks!
10 August 2025 at 14:49 #68706 carolpaBRONZE MemberWhat I understand:
If Wisa connected, you should still be able to use the BL8 independably from the Theatre (when the Theatre is not playing something).If they are DPL connected this is not possible anymore.
So it all depend how you want to use your setup.
10 August 2025 at 17:33 #68711Razlaw
BRONZE MemberThank you. As the 8s would be rears, I have no need or desire to use them separately.
Just thinking of replacing the rear 9s with 8s to get the added height the 8s provide on the floor stands, get rid of the wiring for Receivers with 9s, and get a more cohesive sound with everything being Mozart, as well as everything visually matching.10 August 2025 at 18:34 #68712 MillemisBRONZE MemberWhy not keep the 9’s as is and add the 8’s as heights/WiSA…..I am sure, you won’t regret that.
10 August 2025 at 18:38 #68713 carolpaBRONZE MemberWhy not keep the 9’s as is and add the 8’s as heights/WiSA…..I am sure, you won’t regret that.
So true!
10 August 2025 at 18:56 #68714Razlaw
BRONZE MemberLayout of the room is not good for doing that.
