Home › Forums › General Discussion & Questions › General Discussion & Questions › Wired v Wires?
- This topic has 4 replies, 3 voices, and was last updated 4 years, 1 month ago by
boskonay.
28 August 2022 at 08:52 #38643
boskonay
BRONZE MemberHi all!
I have old power link cables in place – is it a good idea to use a convertor (round connection to rj45) and use these existing wires to connect to ‘new’ Lab 28’s (replacing older 5’s) or should I drop the cables entirely and use the Wireless Powerlink option (from a Beovision) ?
28 August 2022 at 21:54 #38644 MillemisBRONZE MemberI’d say wires in any case….especially now that they are already there.
29 August 2022 at 08:15 #38645boskonay
BRONZE MemberThanks! Was just concerned the existing cables might not be ‘up to’ the standard for fully shielded powerlink
29 August 2022 at 08:23 #38646 Steve at Sounds HeavenlyGOLD MemberHi,
If you previously used Beolab 5 on these round 8 pin cables then they will be fine for Beolab 28, you just need adapters like these to convert them to RJ45 for the new speakers:-Kind regards, Steve.
29 August 2022 at 08:46 #38647boskonay
BRONZE MemberAwesome Steve thank you! Will be back in the morning when your store reopens to order!
