Home › Forums › General Discussion & Questions › General Discussion & Questions › Will Mozart support Masterlink sources?
- This topic has 16 replies, 5 voices, and was last updated 10 months, 3 weeks ago by
beomedia.
21 April 2025 at 05:19 #65202
gburgess
GOLD MemberHas anyone had luck with a Mozart product working with the Beolink Convertor? I easily play Beosound 9000 and Beosound 5 sources on all my pre-network link products (Beosound 1, Beosound Core, A5, M5, A9 4th Gen) via the Beolink Convertor. B&O has only registered receipt of my requests, but so far software updates do not address it.
Favourite Product: Beocenter 9500
21 April 2025 at 10:01 #65208 MillemisBRONZE MemberIt seems that they are not interested – quite a lot of users have asked that question.
Only way is to start the source (e.g. the CD) manually or with the Beo4/the BROne in ir-mode and then ‘Join in’ from the Mozart product.
I do this with my 6500 Master/CD (and the Converter) on my Theatre…..it works.
You get used to it……but it is unfortunately not ‘the real thing’.
21 April 2025 at 19:06 #65251 carolpaBRONZE MemberIt seems that they are not interested – quite a lot of users have asked that question.
Hi MM,
I do understand your reply (and have used this workaround alot). but having the Beoliving Intelligence, I’m still in the impression they work on it. Even “new commands” with “Beoconnect encore” are shown there. But is evolves ectremely slow.
That said, I can start any ML source connected to a BLC on all my NL and Mozart devices using Beoliving Intelligence, directly!
Addition:
One can start a ML source connected to a BLC in the B&o app by selecting 1) the BLC and 2) the source. Then extend this to a NL/Mozart product.21 April 2025 at 21:19 #65268 MillemisBRONZE MemberSure, that is a solution….if you already have – and have the need for – a BLI.
But for this purpose only, the BLI is an expensive extra.
You are right (of course) about starting the source via the app that way.
The reason that I did not think of it is, that I always press play on my 6500-CD and then Join on the BROne/Theatre….that has become a habit.P.S.
Let us hope that they ‘work on it’ – it seems though, that they prioritize other things, when it comes to the regular app.MM
22 April 2025 at 06:11 #65273gburgess
GOLD MemberMM! Thank you for the suggestion. I just used my Halo to join the Level to my Beosound 9000 CD playing through my Beosound 1. It worked! So while the B&O app won’t do it, this did. Thank you for suggesting that! Now I really have to connect up my ML/NL delay box to get rid of the damn echo, since I have Pentas in the room connected to my MCL2AV.
Thanks,
-Gregg
25 April 2025 at 23:23 #65317Stan
BRONZE MemberI have a question about it working in the other direction – sending Mozart sources to ML. At one time, I was able to play my turntable connected to my Balances and then also listen on my BS5 in another room. I even went so far as to program the ML selection on my BeoRemote One to say “Office-LP” (as the turntable and Balances are in my office). This no longer seems to work. In fact, the Balance -> “Line In” option has disappeared from the BLC configuration screen. So it seems B&O giveth and also taketh away.
What are my option? If I connect the TT to the BLC (no speakers), can I easily send the audio to both my Balances and my BS5? I say easily because I’d rather not have to fiddle to get the TT playing on my Balances as this is my most common way to listen to the TT. It it takes a bit to get the audio to the BS5, that’s not ideal, but I can probably live with it.
What of this BeoLiving that Carolpa mentions? I do have a Halo, but have no need for home automation.. and I always thought that was the point of BeoLiving. However, if it can make my audio system more capable (and doesn’t require me to hire someone to program it).
Thoughts?
Stan
26 April 2025 at 00:56 #65320gburgess
GOLD MemberDid you assign the turntable to an unused Masterlink source like CD? The Beolink convertor NL/ML Installation Guide walks through how to do that. I was not able to do this because I have a BS9000 integrated with my BS5, which takes up all of the Masterlink Audio sources. That setup also prevents me from using the USB A AUX input on the Beomaster 5. My implementation involved hooking up a Core to a BS9500 which then has a special crossover cable going to the A AUX input on the BS9000. That is also how I listen to my BG9500 TT.
The only think I can think of in your case is to connect the TT to the Beomaster 5 USB Audio input. This was really meant to provide a Bluetooth music input, but could be used here. There are USB to DIN adapters available. Hooking up the A AUX on the BS5 is discussed on page 23 of BS5 guide.
I have a Beolink Gateway (BLGW) (which looks identical to a Beolink Converter) which provides control of the Masterlink system using the Beolink 2 app on my Iphone, along with home automation. I very much like the Beolink 2 app. Programming the BLGW is challenging. The Beoliving Intelligence (BLI) is the current successor to the BLGW. I got one at a going out of business B&O dealer, but have yet to fool with it.
26 April 2025 at 17:12 #65328Stan
BRONZE MemberI don’t have a Video Master so I have the NL source mapped to TV controls like DVD, DVD2 and V.MEM. I have a BS9000 that is normally the Audio Master, but it is not currently working so I’ve set the BS5 to be the Audio Master. This was all working a few months ago.
A few days ago, I tried to start listening to my Balance sources on my BS5 and none of them were there. The BS1 sources were still there, and they still worked. I looked at my BLC configuration and the Balance mappings had disappeared. I tried to re-add them, but noticed that Balance->Line In was no longer available as an option, only B&O Radio, Qplay, Tone generator and USB. I have no clue what Tone generator does – I’ve tried it hoping it might still map to Line In, but no luck. Same with USB… although I assume it’s audio coming in over the USB connection which I didn’t think was possible. B&O Radio usually works… although sometimes it seems the Balance loses the plot when it comes to NL. Right now, I cannot see any other devices to send audio from the Balance. Rebooting will probably fix it, but rebooting a stereo pair can be a pain. They don’t always come back the way they left.
Connecting the TT to the BS5 is not an option as there’s no room for a TT near the BS5. If I connect the TT to the BLC, then I can see the Converter->LINE IN in the NL configuration panel on the BLC, but I don’t see how to get the audio to the Balance. Getting ML sources to the Balance, say N.Music from the BS5, has always been spotty at best – sometimes it works, other times it boops once, other times it boops twice. It boops more often than it works. Is the Line In on a BLC considered a ML source or a NL source? Maybe I can just configure it in the app – join the Balance to the Converter?
26 April 2025 at 17:52 #65330Stan
BRONZE MemberI think I figured out what happened to the Line-In on the Balance. It used to be that you could set the Line In for no-delay or delay, and only with a delay would it allow you to distribute the audio via NL It was a limitation I could very easily live with. Now, there is no delay, and they seem to have removed the ability to modify the line in – that is, there was a line-in sensitivity or delay settings. No more line-in sensing either. I can no longer find these settings in the app. You must select “Line-In” vs. starting the LP and it automatically switches over.
IIRC, there was a problem with the line sensitivity not working correctly. The non-default setting would not always “stick”. I guess B&O’s solution was to remove all of the line sensitivity settings. Grrrr. 🙁
26 April 2025 at 18:14 #65331Stan
BRONZE MemberI’ll just keep talking to myself about this. Maybe someone might benefit some day.
Now, I’m remebering that the Balance always had a delayed line-in input which stopped it from being used with a TV. Now, it seems like they’ve eliminated this delay (i’m only comparing time from needle drop to audio so there may still be some lip sync issues). Yeah, for the TV people. Boo, for people who want to send their TT audio to other rooms.
In any event, I sent a strongly worded email to B&O support about this. That will show them! /sarcasm.
I think connecting the TT to the BLC will fix my issues… so I have to fiddle with the app to listen to my LPs… I have to do that regardless since line-in sensing doesn’t seem to work anymore.
Still curious if BeoLiving with a Halo can help anything here.
26 April 2025 at 18:38 #65332gburgess
GOLD MemberStan –
You remind of the other reason I ran out of ML names to assign to NL sources; I have a BV7-40 in the room with the BS9000, and my BL1’s and a pair of BL6000’s are connected to it for playing music. The video sources that were easily accessible from a Beo4 were taken up. B&O blew it when they added N.MUSIC and N.RADIO and re-used existing Beo4 codes for PHONO and ATAPE2 instead of figuring out how to retain them in the ecosystem just for situations like this.
If you go in the OneApp, go to your Balance and under Settings there is a tab “Get Beta Updates”. Under there you can sign up to become a beta tester. This allows you to submit new ideas and issues to the software development team. There is a separate Mozart Beta test going on (with quite a bit of new features being added), and I also found out there is a separate one for “ASE and Halo remote” which is for all the “pre Mozart” Network Link products. I’ve been on the Mozart Beta for a year, and now just joined the ASE one, as I am requesting that they create the feture to have A6’s to operate as Stereo pairs, which Mozart speakers like the Level can. When you sign up, B&O frequently does automatic software updates to your products and the OneApp on your phone. This might be a way to get your issues resolved.
As I’ve been fooling around with this issue, I’ve found that the Beolink Converter gets confused after a few days and I have to power cycle it. This could be due to the frequent software updates that come with being a Beta tester.
This has also caused me to spend more time with the Halo, and I’m finding the more I use it the more I like it. I have not been watching much TV, but I think I will start using my Avant 55 with the Halo to see what that is like.
I’ve never used the line in on the BLC. If you play with that, please report your progress. I have no idea if it is considered an ML or NL source.
You gotta get your BS9000 repaired! I have multiple shops in the US that I’ve had great experience with.
26 April 2025 at 18:49 #65333 carolpaBRONZE MemberI think connecting the TT to the BLC will fix my issues… so I have to fiddle with the app to listen to my LPs… I have to do that regardless since line-in sensing doesn’t seem to work anymore.
I would try the next settings/connection:TT line-in connected to the BLC set as VMaster.
Open the B&o app, select the BLC – select the Line In of the BLC as source – expand the multiroom experience (of the BLC) to the BS Balance.You should hear the record playing on the Balance.
I just moved to a new home, but in the previous house I could start and listen to all my ML sources (ph7000, cd7000, atape7000, cd3000, cd1, cd2, cd3, cd4, cd5, cd6 of the bs9000, beocenter 2 cd, beogram 6000/4000/4002) to all my NL/Mozart devices (Shape, Essenses, M3, BS35, Theatre…… and so on) with just 3 buttons on the Halo. (new house – new settings – still have to adjust the BLi software).
is it nessescary… no… but it is fun to have these option available
28 April 2025 at 19:32 #65368Stan
BRONZE MemberThanks for your replies.
B&O did actually respond to my request and asked me for more information. When I went to look for this information, the line-in settings now appeared again in the App just like it used to be. Not sure what happened because I didn’t change anything, and I don’t recall updating the app, nor the Balance, but, whatever, it is all working again just like before. I did leave the house for a day and a 1/2 so who knows what the cat did while I was away :D.
@gburgess – About repairing my BS9000. What repair shops have you worked with in the US? I used to have B&O service center about 30 minutes away so I was spoiled. Unfortunately, he retired. B&O says to talk with the Cincinnati store as that is the closest to Chicago, but I found it easier to deal directly with the repair shop without the dealer sitting in between.Also, I’m not excited about joining the beta program. There are enough quirks with the regular software. However, I am glad that you find it useful and worth your time. Ultimately, users like you should make the software better. I definitely don’t want to do anything to confuse my BLC. When I reboot it, I need to leave it unpowered for ~24+ hours or else it doesn’t boot up correctly.
29 April 2025 at 04:35 #65370gburgess
GOLD MemberStan – I was unable to send you a PM. Try sending one to me, gburgess.
29 April 2025 at 23:09 #65383Stan
BRONZE Membergburgess – tried sending you a PM, it looked like to worked on my end.
1 May 2025 at 17:26 #65408gburgess
GOLD MemberTwo shops I have terrific success with are Atlantic Systems in Boston. They are a B&O factory service center for decades. 781 826-8760. They did the impossible and repaired a VX5000 for me.
Benny Amina at Modular Electronics in Roswell GA. He is a true craftsman, former B&O factory, and repairs systems as well as very fine work like the Beolink 7000 remote and re-tipping B&O phono cartridges. 7704101122.
9 May 2025 at 17:41 #65513beomedia
I was not aware it was this easy. I thought I had to activate the ML source on the NL/ML Converter first. Thank you for the tip, pressing “JOIN” from the Beoremote One works fine. However, I can’t find a similar approach from the app as “JOIN” is not in the app, only “Multi Room” but haven’t worked out how to play on the Theatre (sound from ML stereo) without first activating the source in the NL/ML Converter.
Tips are welcome 😊 -
