Home › Forums › General Discussion & Questions › General Discussion & Questions › Wi-Fi networks and B&O
- This topic has 21 replies, 9 voices, and was last updated 2 years, 5 months ago by
Vedet.
22 October 2023 at 10:27 #49266
LeosgonewildBRONZE MemberI have the Google VYUDCFDX3VF8H mesh with two mesh points. Works flawlessly.
27 October 2023 at 02:01 #49267Vedet
BRONZE MemberIf the router is completely disconnected, to replace it with a new one, Beosaund Emerge will not be able to connect to the network due to its absence. You wrote that you need to disconnect Beosaund Emerge from the power supply, and then reconnect it to the power supply and it will enter the network setup menu automatically.
As far as I understood correctly, after disconnecting the router from the network, I also have to disconnect Beosound Emerge from the network and connect BE back to the network, then it will automatically switch to network setup mode, and where in the Application will I have to enter the password for the new network?
Will there be some window for me to see a new network and enter a password?
Or if to keep old the SSID and password for connecting to WI-FI the same in the new router, then the connection will also happen automatically? -
