Home › Forums › Product Discussion & Questions › BeoVision › What’s with the Beovision Avant?
- This topic has 11 replies, 9 voices, and was last updated 7 months, 2 weeks ago by
Billywedlock.
29 August 2022 at 02:53 #38652
jamesj
BRONZE MemberI have been considering buying a B&O TV (Used), to get more out of my speakers. I noticed that the Avant is significantly “cheaper” on eBay. Is there something I should know here? Seems like a pretty high spec’d tv, looks good… Why is the resell so much lower?
Thanks in advance.
29 August 2022 at 15:02 #38653beosince
BRONZE MemberA lot of Avants were sold, so there are quite simply many on the market which dictates price. Moreover the video board is a known weak point in there TVs and costs about 1000€ to exchange.
29 August 2022 at 15:20 #38654355f
BRONZE MemberThe Avant is a lovely TV.
The video board went three times in mine, roughly 1000 to fix it and very long delays as the board has to be programmed to the individual TV
as a result of this I would never buy one
29 August 2022 at 15:29 #38655 MillemisBRONZE MemberBe aware that there are two versions of the Avant.
The one that is mentioned above is the 1 gen.
As far as I know the costs for the DVE replacement are not that high anymore (as a dealer before you decide).
If you can live with this risk and am willing to put some money aside from the start, you will get a pretty decent Beovision. Furthermore you must know that you’ll have to add an AppleTV/Chromecast etc solution, since the smart tv platform is not up to date anymore.
The second version (called NG) is younger, but is based on an Android platform, which a lot of the B&O fans does not like.
However, it is said to run rather smooth with the latest updates.
Also here most people add a ATV….
There are some of these that may have display issues.Both are based on the BSys4 audio engine, which gives you a lot of options, when connecting additional speakers.
Many – both 1 gen and NG – are being used nowadays and people tend to like them, but you must consider that these are old tv’s.
29 August 2022 at 22:42 #38656boskonay
BRONZE MemberFor balance, I have a gen 1 Avant now for about 5-6 years and it’s absolutely wonderful still.
29 August 2022 at 22:52 #38657Sandyb
BRONZE Membersame here – 5 or 6 years in to mine, and its been all good.
30 August 2022 at 15:45 #38658checkler
BRONZE MemberMy Avant 55″ lasted about three years before the video engine went. It would have cost about 1700.00 dollars to replace. This is not all what I had expected for a set that at the time cost around 8,000 dollars plus installation.
30 August 2022 at 20:13 #38659 MillemisBRONZE MemberFor the record…
….my Avant 1st gen runs perfect.
However, I had to have the DVE exchanged a year ago – which I ‘happily’ paid the price for.
Would have been a crying shame to have such a nice BV trown away because of this.
1 September 2022 at 22:45 #38660 9_LEEBRONZE MemberJust for the record, the video engines fail due to overheating issues which degrades them until they fail. The new ‘improved’ replacement video engine just has a heat sink attached to it to help with cooling.
If you want to prolong the life of your Gen1 Avant remove the rear covers to let it breathe and cool – especially if it’s on a wall or has boxes on the rear which only add to the heat.
Lee
3 September 2022 at 21:07 #38661355f
BRONZE MemberWith the two replacement boards that I had from B&O , I examined them against the original and could find no addiitonal heat sinking.
I subsequently ran the avant with rear covers removed and each failed after about 15 months.
My conclusion is that the boards are ‘fixed’ by B&O but many other components are not replaced , as a result they fail repeatededly
The worse is the huge delay in time to get a replacement board programmed up, in both cases it took over 6 weeks— Never again.
You can almost get a basic LG for the cost of the repair and enjoy reliability and a huge picture improvement.
3 September 2022 at 22:19 #38662jamesj
BRONZE MemberThanks for all the advice. I’ll definitely pass on the Avant. With the new Theatre, which I took a look at in Berlin on Friday, it makes no sense anyway.
Definitely the right direction for B&O.
30 September 2025 at 08:57 #70002Billywedlock
BRONZE MemberThis is an old topic, but maybe some people will be researching info about a used Avant.
I paid over 2ok GBP for my 85 inch tv. When functioning it was amazing. But it needed various video boards (thousands spent again) , the drop down speaker mechanism broke, and the final nail in the coffin, the screen failed and cannot be repaired. As I travel a lot, the actual hours of use on the screen were minimal compared to daily use. B and O did offer a discount on a new system, but the desire to spend again thousands on such unreliable products is zero. I have spent , I guess 70k plus on B and O equipment, the style worked for my house, sound good enough, etc. But I would never do it again. Unreliable product, and the manufacturer did not support a clealry defective product. I have many other screens, older than the Avant, all work perfectly, zero defects, have never needed any repairs or spend. But I will end up having to get the sound bar so I can use my other speakers, but it will be through gritted teeth.
I will deliver this monster pile of junk to B and O head office though. Just so they understand what it is like.
