Home › Forums › General Discussion & Questions › General Discussion & Questions › What speaker is this?
- This topic has 10 replies, 4 voices, and was last updated 3 years, 2 months ago by
KolfMAKER.
4 February 2023 at 08:06 #43565
Beo3000fanBRONZE MemberHi. Does anyone know what speaker this is?
4 February 2023 at 21:19 #43566 KolfMAKERBRONZE MemberIt looks a lot like one of the speakers in the Grundig line of ‘Grundig HiFi box Lautsprecher’. For instance the Grundig HiFi box 740:
https://www.radiomuseum.org/r/grundig_hifi_lautsprecher_box_740.html
But it probably is a different model. What I can say is that Grundig produced several speakers, with all wood front grilles. And with the slits horizontally. The 740 and 525 are examples of this design.
have a look over here:
http://www.hifi-wiki.de/index.php/grundig_box_525
This Wiki has an over of most grundig loudspeakers with specs and pictures.
By the way, most Grundig all wood loudspeakers with horizontal slits, were produced in 1970.
5 February 2023 at 13:33 #43567 hemenexBRONZE MemberReminded me of some Telefunken speakers I had in 1970…
could be one of those:
hx6 February 2023 at 08:41 #43568 hemenexBRONZE MemberOn second thought – the „slots“ don‘t go from end to end.
so – obviously not that one, sorry
6 February 2023 at 09:00 #43569 KolfMAKERBRONZE Member- Can you share more pictures?
- Also one from the backside?
- Are there any labels visible?
6 February 2023 at 12:58 #43570olivierc
BRONZE MemberQuick search on Google, after reading KolfMAKER suggestion.
It looks like a Grundig speaker box type 45.
I can only spot few differences.
It should be placed vertically, a metal Grundig badge should be attached on the bottom right side of the front slitted surface and the standing legs seem to be missing.Maybe an expert of vintage Hi-Fi can clarify.
Thanks.
Olivier
6 February 2023 at 19:07 #43571 KolfMAKERBRONZE MemberThanks for sharing your idea Olivier!
The Grundig box 45 comes close, but is not the same. The speaker we are looking for has horizontal slits, instead of vertical.
Also, the front panel is completely integrated with the speaker casing. It does not look like it can be taken off to access the drivers. This looks different on the Grundig 45.
That’s why I think it is interesting to see the backside.
(Maybe, it is not a loudspeaker;-)
7 February 2023 at 09:58 #43572 Beo3000fanBRONZE MemberWow, thanks for all the answers! Hereby some more pictures
7 February 2023 at 10:10 #43573 KolfMAKERBRONZE MemberHi @Beo3000fan
Thanks for the extra pictures.Can you do following?
- Make a picture of the backside-panel (the one you took away to see the inside)
- Let me know the measurements of the loudspeaker box (W x D xH)
7 February 2023 at 10:54 #43574 Beo3000fanBRONZE MemberI´ll write down the size of the speaker. The back panel I don´t know, it came as in the pictures. The gray back panel offer the possibility to “store” (wrap around) the speaker chord, so maybe the gray panel is the back panel?
7 February 2023 at 12:14 #43575 KolfMAKERBRONZE MemberYes, size will help. I think it will be smaller than I first thought. Especially because there is only one driver in the box.
The wooden casing looks like there should be a back panel.
The grey back panel looks more modern that the speaker and casing.
This speaker now makes me think of a loudspeaker that came with a record player with built-in amplifier.- Yes, please let me know the measurements.
- By the way, where did you get this speaker / do you have any background info?
