Home › Forums › Product Discussion & Questions › BeoLab › Volume problem
- This topic has 0 replies, 1 voice, and was last updated 4 weeks ago by
Mikkel Vilsgaard.
11 March 2026 at 20:25 #76845
Mikkel Vilsgaard
BRONZE MemberHi
I hope someone here has experience with this setup.
I have connected my BeoLab 6000 speakers and a BeoLab 2 subwoofer to a TCL C855 TV using a OneRemote HDMI ARC to Powerlink converter (type 30017713).
The system works, but I have an issue with the volume control. The sound almost jumps directly from 0% (completely silent) to around 10%, where it is already quite loud, so there is basically no usable volume range between 0 and 10%. This makes it difficult to have low background sound.
I tried setting the BeoLab 2 to LINE, which lowers the level, but then the speakers start humming, so that does not seem like a good solution.
My current setup is:
TV (HDMI ARC) → OneRemote ARC to Powerlink → BeoLab 2 → BeoLab 6000
Has anyone experienced something similar with this type of setup?
I am wondering if the solution could be:
– a Powerlink cable with attenuation (-10 dB)
– a different way of connecting the speakers
– or a setting in the converter or TV that I may have missed.
Any advice or experience would be greatly appreciated.
Thanks in advance!
