Home › Forums › General Discussion & Questions › General Discussion & Questions › Volume control on Beoremote One stopped working
- This topic has 12 replies, 5 voices, and was last updated 6 months, 1 week ago by
Saxpy.
28 May 2025 at 19:30 #65882
Saxpy
BRONZE MemberHi,
I have a Stage and Beoremote One and today when I turned on the TV I noticed that the volume keys don’t work at all anymore. Neither of them actually which seems a little odd, then again I’ve never looked inside the on circuit board. Flashbacks from the Beolink 1000 era and the dome sheets… 😨
Through the app, the volume control works fine so it’s not the Stage.
Know issue that the volume keys stop working or a potential SW issue?
29 May 2025 at 07:41 #65893
NQVHNWIBRONZE MemberThe keypad is an all-in-one moulded design with the base-layer being a thin rubberised plastic membrane fused to the buttons. This presses a metal foil on the circuit board to activate control.
I can confirm that the keypads do fail when fatigue sets in. Mine happened on the diamond/centre “go” button.
I suspect that a similar fatigue may have happened to yours? Its a non-repairable part and (was – in January 2025) a GBP180 fix for a new keypad.
29 May 2025 at 17:37 #65922Saxpy
BRONZE MemberThanks for the info. Mine is about four years old, I would have hope that it would last a little bit longer than that.
29 May 2025 at 19:50 #65923 Severed_hand_of_skywalker
BRONZE Memberunpair the remote and re-add it.Location: Toronto, Canada
30 May 2025 at 19:39 #65944Saxpy
Yeah, that was the first thing I tried, unfortunately had no positive impact.
5 June 2025 at 14:18 #66201Saxpy
BRONZE MemberFYI.
After 4 days it magically started working again…
B&O support says it is a known issue they are working to fix, but that is about as much info I could get out of them.
20 July 2025 at 19:02 #67394 TimBRONZE MemberI have the exact same problem now. Volume control not working with my BeoSound stage. Happened to start after the software Update of our LG OLED C4 my wife said.
Seems the remote is working with the BeoSound Core so I think it is a B&o or LG software issue
20 July 2025 at 20:34 #67416Saxpy
BRONZE MemberI’ve had it happen once more, but again it magically started working after a day or so.
Unfortunately yesterday my Stage completely died on me. No lights, no reaction, not able to reset, guessing it’s something wrong with the PSU, but will probably have to have it shipped off for repair….
21 July 2025 at 08:06 #67449 TimBRONZE MemberThis does not sound very good.
i hope this won’t happen to mine as we stored it for 2 years and just started to use it.
21 July 2025 at 08:09 #67450Saxpy
BRONZE MemberMine is 3,5 years old so is it of warranty unfortunately…
13 August 2025 at 16:43 #68757Saxpy
Yeah, turned out to be a defective PSU and Ethernet board, that latter I have a hard time to understand, anyway, €500 and it is as good as new… Though still no update to fix the intermittent loss of volume control. Oh well, you can’t have everything I guess… 🙂
13 August 2025 at 19:38 #68759beojeff
BRONZE MemberI have rendered 2 Beoremote One remotes lifeless by accidentally rolling over and sleeping on them.
15 September 2025 at 15:46 #69693 -
