Home › Forums › Product Discussion & Questions › BeoVision › Vale BV8-40 ?
- This topic has 6 replies, 3 voices, and was last updated 2 years, 7 months ago by
elephant.
19 June 2023 at 08:36 #47239
elephant
MemberToday, during routine upgrades by a certain consumer monitoring firm that required much cable pulling and black box swap overs, our beloved BV8-40 was dislodged and fell against the technician’s shoulder ???
Th technician is OK
But our BV8-40 is now ?
So I would appreciate some opinions … apart from have a triple scotch ? (more likely 6 beers)
What replacement path should I look at ???
What do you when an upgrade is forced upon you when this is your life …
The BV8-40 as some will recall from my site diagrams of circa 2012 is the core of our system:
- Its SurroundSound with two BL3s, two BL4s, and a BL19
- And a MasterLink to a BeoSound 4, and this year also a Beosound 3200
- B&O Wireless Link to two remote rooms
- And via ML/NL Converter connectivity to a Core … two BL20s
- And also ML/NL connectivity to an Essence … two BL6000s and a BL12
- Four Beo4 remotes, one BeoRemote 90, and three BeoLink 1000 remotes
- A Become 6000
- And a defunct BeoPort
And so my friends, any thoughts ?
19 June 2023 at 08:37 #47240elephant
Member19 June 2023 at 09:17 #47241 MillemisBRONZE MemberSince it seems that you have some experience with the ML/NL Converter, you will not necessarily have to stick to a ML tv part!
If you want to maintain the ML there, you will need a BV10 (or a BV8-40 replacement).However, I would use the opportunity to go all in on NL (with the additional converter you already have) and look for a preused BV11.
Or rather – if funds allow – a BS Theatre and the LG tv!
As much as I also liked my BV8-40, I am sure you won’t regret that.MM
19 June 2023 at 09:42 #47242petermc
GOLD MemberNot good. Bet there was much wailing and gnashing of teeth by the technician?
I have a BV10 that you could have for a reasonable price. That way everything should work as it did previously (hopefully….)
Peter
22 June 2023 at 01:25 #47243elephant
MemberThanks Peter !
You’ve got mail.Thank you MM … that was the direction I was leaning, however Peter’s suggestion is interesting.
I need to dig into some manuals 🙂
Ed
29 June 2023 at 09:41 #47244elephant
MemberToday saw the arrival of our replacement… a BeoVision Horizon… and the departure of the BV8 …
And MM was correct, after Jonathan worked his integration magic, we have an even better multi-room experience.
29 June 2023 at 09:43 #47245elephant
Member -
