Home › Forums › General Discussion & Questions › General Discussion & Questions › unable to store speakers role settings
- This topic has 6 replies, 3 voices, and was last updated 2 years, 11 months ago by
ysuberu.
28 April 2023 at 09:04 #46085
ysuberu
BRONZE MemberHi,
Could you please advise me regarding this situation. I’m trying to add my beolab 8000 speakers as a surround speakers to my beovision 7-40 TV but its turning on/activate the speakers but no sound and not adding it to the TV.
28 April 2023 at 21:36 #46086 MillemisBRONZE MemberNot knowing which version of the BV7 you have and the configuration overall…..the most obvious reason is, that you can only add surround speakers, if you also have front speakers.
28 April 2023 at 21:46 #46087ysuberu
BRONZE MemberHi,
Thanks for your comment, there is front speaker working perfectly.
28 April 2023 at 22:12 #46088 MillemisBRONZE MemberWhich version of the BV7 do you have?
Do you have a centerspeaker also added?
28 April 2023 at 22:40 #46089ysuberu
BRONZE MemberBV MK4 … Yes centre speaker connected and working perfectly
3 May 2023 at 15:58 #46090 stefanBRONZE MemberSounds like you just have a single speaker connected as a front speaker (center speaker?)
In this case you have to add front speakers left and right first – then you can add surround speakers left and right .
Hope this helps (would help to know more about your setup….)
Stefan
3 May 2023 at 17:54 #46091ysuberu
BRONZE MemberThanks, I was able store the speakers as left and right front but no sound.
