Home › Forums › Product Discussion & Questions › BeoMaster › Tuning New Stations on an MCP6500?
- This topic has 3 replies, 3 voices, and was last updated 6 months ago by
Tignum.
13 September 2025 at 16:00 #69602
CharlieWednesdayGOLD MemberI really should be able to figure this out for myself but can’t! I have Beosystem 6500 with an MCP6500. I cannot however figure out how to tune a new radio station – I’m only able to listen to presents.
There is a manual for the MCP6500 here on Beoworld, but for some reason it has pages missing, and they are the radio pages! I did find the same question on the old forum – the answer was ‘use the Tune button’ but the MCP6500 doesn’t have a Tune button. I think the person answering may have been thinking of the Beolink 7000.
Any ideas?
13 September 2025 at 17:00 #69604billb
GOLD MemberHi,
I think the process is like this on the MCP6500:
- press Radio
- press GO TO (F will appear in the display to indicate it’s waiting for a frequency)
- use the number buttons to key in the desired frequency
- when you’re on the station you want, press preset (on the lower control panel)
- then use the number buttons to select the desired preset
- then press store
Good luck!
Bill
13 September 2025 at 17:59 #69605 CharlieWednesdayGOLD MemberThaks Bill, yes that was it. I also discovered that if you press GO TO, you can then hold down << or >> to manually search through stations, if you don’t know the frequency.
21 September 2025 at 18:24 #69826 TignumGOLD MemberHello CharlieWednesday, I found a (edit:) DUTCH hardcopy of the MCP5500 manual. When I will find a moment I will try to scan it completely. (edit:) But perhaps better if someone can make a scan of the English manual :-).
Regards, Johan
