Home › Forums › Product Discussion & Questions › BeoLab › Triggered Beolab 4000 switching on and off
- This topic has 2 replies, 3 voices, and was last updated 2 years ago by
Jojoe.
14 September 2023 at 06:36 #48949
LeosgonewildBRONZE MemberSet up:
Denon – rca with trigger- powerlink – Beolab 4000 rear – powerlink daisy chain – Beolab 4000 front
Issue:
Beolab 4000 rear rapidly turning on and off constantly.
Thoughts:
I cannot see that this is a cable issue, since the issue is happening on the first speaker in the chain. The last speaker in the chain functions normally.
I believe there is a issue on a circuit in the Beolab 4000 in the rear.
The speaker with the issue is the ceiling rear left in my Atmos setup, so I have just turned it off for now, but would be nice to get it sorted.
14 September 2023 at 08:14 #48950 Steve at Sounds HeavenlyGOLD MemberHi Leo,
If you switch the affected speaker between left, right and line via the input switch, is the issue still there please? It may be a faulty switch as these aren’t particularly robust.
Kind regards, Steve.
26 February 2024 at 18:48 #48951Jojoe
BRONZE MemberHi Leo,
I have the same kind of Problem, my Beolab4000 is also working intermittently.
switching from red to green.I’ve read somewhere else that the rotten foam inside could
be the reason, causing small shorts on the circuit boards inside. I’m going to clean them
shortly and see if it works..
best regards Jojoe
