Home › Forums › Product Discussion & Questions › BeoSound › Totaly weird behaviour of the horizontal Beosound 9000 with Beo4
- This topic has 4 replies, 2 voices, and was last updated 2 years, 1 month ago by
69er.
24 January 2024 at 11:51 #52407
69er
BRONZE MemberHi guys,
i am close to getting nuts.
I have 3 Beosound 9000 here and also a couple of Beo4.
All Beosound 9000 work perfectly with every Beo4 when mounted vertically on the stand.
When i lay it down horizontally on the table stand (and of course change the arrows on the back) ALL three Beosound 9000 do not react properly to the Beo4 commands. They do, but you need to press several times the same button, get closer to the BS, change angles – all that stuff.
And i hear the Beo4 commands in the loudspeakers (Beolab 6000). A small buzz with every click.
I have absolutely no clue, why the position of the BS should have an impact on the remote control behaviour.
Happy for any help
69er
25 January 2024 at 00:31 #5240869er
BRONZE MemberI think i have an idea. After searching half of the internet and finding one post with some inteference to a plasma screen in the same room – i turned of the light above the player and now it works much better. WEIRD
So it has something to do with the LED lights in my wall lamp.
But – i can still hear the commands of the beo4 with a small buzz in the loudspeaker.
Any idea?
Best regards
69er
25 January 2024 at 00:54 #5240969er
BRONZE MemberOk, solved also the buzz problem. Connected different cables to the Beolabs and now it sounds fine.
Thanx
69er
10 February 2024 at 21:51 #52410Anonymous
InactiveYes
both plasma and bad/poor enginering leds
can cause disturbing of ir for b&o because it
Interfeering on 455khz frequens that b&o use
14 February 2024 at 23:31 #5241169er
BRONZE MemberThanx. By hiding the connector section it worked. Was some interference
