Home Forums General Discussion & Questions General Discussion & Questions Thumbs up for Danish sound parts (for MCP hinges and Beolink parts)
  • #73356
    lausvi
    SILVER Member
    Just to give a shout out to Danish sound parts once again; I only recently learnt that they also make reproduction Master Control Panel hinges and I love those! I have three MCPs and all of those had broken hinges which made them look slightly miserable as the flip-doors wouldn’t sit straight. I have now replaced the hinges on all of them and they look nice again!
    There are two types of the hinge; my MCP5500 had the (earlier?) short version which was much more work to replace. The long version is much easier.
    See their parts for remote controllers: https://www.dksoundparts.com/product-category/remote-controls/
    I also replaced the keypad on one of my BL1000s along with the missing rubber feets (those also fit the MCPs!) and that really makes a big difference!
    Also a tip: if you find a part that’s listed on the old Beoparts.com, you can use the contact form to ask getting them available to your order on dksoundparts.com, should be usually possible.
    Tignum
    GOLD Member
    Yes, just great that such specific parts are available to keep our B&O gear in great shape.
    These feet are on my BeoMaster now https://www.dksoundparts.com/product/rubber-feet-set-beosystem-5000-5500-6500-7000/ . Very pleased!
    Regards, Johan
    Rolf2
    GOLD Member
    The feet also fit the A4 CD rack wave, well done, dksoundparts 👍!
    Favourite Product: BeoSystem 4500
