Home › Forums › Product Discussion & Questions › Other › System Cabinet SC80 Refurb
Tagged: Beomaster 8000, Cabinet, SC, sc80, System cabinet, veneer, wood
- This topic has 3 replies, 2 voices, and was last updated 1 year, 2 months ago by
B&O Orlando.
21 January 2025 at 03:32 #62940
B&O OrlandoBRONZE MemberHey everyone,
Pround new owner of an SC80. It’s in okay shape, but needs a good cleaning/oiling and has some discoloration from what I am assuming was water. So far I have only removed and cleaned the sliders and vacuumed the rest with a horse hair brush.
I don’t have a lot of experience with wooden furniture, so any input would be amazing.
What is the best process to remove years of dust and a bit of dirt? Any advice on fixing the discoloration? I’m not super keen on sanding and refinishing the whole thing, can it at least be brought back to life with some fresh oil?The aluminum edges seem slightly yellow, like they were coated with something perhaps, is this standard? The sliders are either rusting in areas, or the black paint is rubbing off easily, do they need sanded and repainted black?
Thanks all,
Jacob
You must be logged in to view attached files.Location: Winter Park, FL
21 January 2025 at 03:38 #62945 B&O OrlandoBRONZE MemberSome more photos:
21 January 2025 at 19:22 #62972mcevedy@mac.com
GOLD MemberI would try some Danish Oil on the wood. My SC80 was not varnished so you might find it is just the wood drying out. A very light sand of the worst bit might be necessary.
21 January 2025 at 21:27 #62977 B&O OrlandoBRONZE MemberI’ll give it a shot. Any advice for Danish vs Teak oil?
