Home › Forums › General Discussion & Questions › General Discussion & Questions › Stage / contour problem
- This topic has 11 replies, 6 voices, and was last updated 1 year, 9 months ago by
M00NMAN.
4 June 2024 at 11:08 #56253
EgonOlsen
BRONZE MemberHi,
in the current App i miss the settings for upmix etc. i saw these settings in older versions of the app. It was in the back screen and i have to slide from button to top
can anybody help me?
greetings
4 June 2024 at 11:19 #56255 MillemisBRONZE MemberI do not have a Stage – however:
There have been some changes in the app with short and longpressing of some of the buttons.
Have you tried, if there is a change when you long press the menu?
4 June 2024 at 11:43 #56256EgonOlsen
BRONZE Memberhi,
thank you for the reply
which menu do you mean? Also i heard from long and shortpressing. But i do not know where i should do this.
also i can’t find an explanation for this on the bo website.greetings
4 June 2024 at 21:29 #56266 MillemisBRONZE MemberBest stay tuned for a reply from an actual Stage/Contour user – there must be someone here!
My reply was just a hint, that might help – as stated I can not test it on a Stage.
With the Theatre it looks like this, when I press the menu button for Sound Modes shortly.
When I long press a more advanced menu for the actual Sound Mode appears.
N.B. This is from the beta version – I do not know, if this also is in the regular version. Sadly you find little to no explanation for this behaviour on the B&O site…..I found out per accident.
5 June 2024 at 21:36 #56298smg
BRONZE MemberI have Stage and confirm it’s missing from 5.9 or 6.0 app version on iOS. I use testflight and dowgraded to 5.8.1 which is ok.
I have no idea if they have any QA department, but to me seems like paying premium price and always run on beta app. Pathetic.
8 June 2024 at 18:01 #56373EgonOlsen
BRONZE MemberThank you. I wrote to support. No answer.
greetings
10 June 2024 at 12:54 #56404EgonOlsen
BRONZE MemberHi, bo support wrote to me. Since 5.9 the UI has changed.
the developer is informed. In Future updates the function should be returngreetings
18 June 2024 at 21:34 #56575TinusAMS
BRONZE MemberI don’t have a Stage, but it seems it’s fixed in the current app release (6.0.1)
19 June 2024 at 19:51 #56609EgonOlsen
BRONZE MemberI can’t see any changes. Can you make an Screenshot?
20 June 2024 at 00:24 #56619 jmenBRONZE MemberStage>Sound Modes>Create New
21 June 2024 at 14:44 #56663EgonOlsen
BRONZE MemberI give up. On my contour it doesn’t show this again.
22 June 2024 at 21:41 #56943 M00NMANBRONZE MemberI am experiencing the same issue for my BeoSound Stage. Is there a new update coming out to fix the issue?
