Home Forums Product Discussion & Questions BeoMaster Speaker for BM800
  • #71956
    Pindsen
    The speaker seems special in the Beomaster 800, it has a 50R resistor built-in and is hard to find a replacement for.
    I have a BM800 where one of the speakers are dead (infinite ohm across coil), so either I find a BM800 I can take the speaker from or I find an ordinary speaker (e.g. 4 or 8ohm) and add a series resistor to it. Do any of you know where to find a replacement speaker (it is 13cm wide and 7,5cm height).
    I have also tried to see if other Beomaster have the same speaker, but cannot find any – or have I overlooked something?
    /Pindsen
    #71969
    Skyler Clooney
    @Pips NYT Hi Pindsen, can you post a close-up photo of the speaker (front and back) and a photo of the inside of the cabinet where it mounts?
    #71975
    viloka
    Unrelated, but funny how niche tech problems like this remind me of games like <strong data-start=”1578″ data-end=”1610″>Fnaf — simple on the surface, but full of hidden technical quirks once you dig in.
    If you want, tell me whether originality or sound quality matters more to you, and I can suggest specific modern speaker models that fit best.
    #71982
    Pindsen
    Here are pictures of the speak. It is 13cm wide, 7,5cm height and diagional between upper left and lower right screw are 12,7cm.
    #71986
    Pindsen
    Here are pictures of the hole in enclousure.
