Home › Forums › General Discussion & Questions › General Discussion & Questions › Sound quality difference on Beovision and Core
- This topic has 1 reply, 2 voices, and was last updated 6 months ago by
matador.
29 September 2025 at 21:57 #69998
Eric Andreux
BRONZE MemberHello Beolovers,
It’s been a long time since I visited the forum. Hope you can help and give me some hints.
I have a beovision Avant 55, a pair of beolab 17 and a Beosound Core to play a beogram 7000. When I connect the beolab 17 on the beovision, and want to listen to music (Deezer or Beogram) through the Core using only the beolabs 17 (I created a speaker group on the beovision), I have a really degraded sound quality if I compare to the solution when the beolabs are connected to the Core directly (hope it is clear :-)).
It is just problematic since I cannot use the beolabs as front left and right fort the beovision if I want a good sound quality with music.
Do you have any ideas to fix the problem or do you encounter the same situation ? It seems the sound treatment of the Beovision affect the sound quality.
Thanks for your help, have a nice listening evening on yours systems
Eric
Favourite Product: Beosystem 7000 in White
30 September 2025 at 12:01 #70007 matadorModerator*Duplicate threads removed.
