Home › Forums › Product Discussion & Questions › BeoCenter › Software for single chip computers etc. contained within products.
- This topic has 6 replies, 4 voices, and was last updated 8 months, 1 week ago by
Glitch.
12 July 2025 at 23:26 #66974
Stephen Taylor
SILVER MemberHi,
I’m considering buying a Beocenter 7700 which is a great price even though it’s not working. I was wondering what people do when a software-containing component in a product stops working.
Is there a repository of software images contributed by people somewhere? Apart from that the only solution I can think of is appealing on forums for users who might have spares. I can’t imagine anyone would be keen on removing an eeprom/SCC from a working product and copying the image so that it can be used to re-flash a blank device.
Apologies if the answer is well known – I did do some searching before posting.
Cheers!
14 July 2025 at 06:42 #67020artig
BRONZE MemberAs far as I’m aware there is no such repository, and doubt that even the B&O archive has copies of the software images.
There are a couple of potential problems:
- The single-chip controllers are mostly mask programmed and it’s not possible to read the ROM memory from them.
- There are no pin-compatible controllers with eeprom or flash memory available in most cases.
The Beocenter 7700 uses a Mostek 3870 controller (same as Beomaster 6000) which was not available in an EPROM version, but was available as a bond-out with a piggyback board where an EPROM (2716) could be mounted. I have one of these, but without the software image it’s not really of much use for these purposes. I don’t know if any lab samples or pre-production samples were produced with the piggyback chip.
I have heard of someone developing a replacement chip for a Beomaster 8000 using a completely different microchip (PIC, perhaps) on a small circuit board, writing a program from scratch. Someone else was planning the same for a Beomaster 6000 but don’t know if that ever came to fruition. The more usual option is to take a chip from a product which has died of other causes than a SCC failure.
You must be logged in to view attached files.14 July 2025 at 11:03 #67022Stephen Taylor
SILVER MemberThanks very much for the reply – great details in there.
Although creating a replacement from scratch is really appealing to me, it a hell of a lot of work. For me the hardest part would be reverse engineering the requirements. Even so I’m tempted to see how far I can get with something like a BBC microbit and a Heath-Robinson DIL adaptor.
Cheers
Steve
14 July 2025 at 11:10 #67023 T.W.GGOLD MemberActually somebody has done some cloning of the old Bang & Olufsen Eproms for repair, backup, replacement:
14 July 2025 at 14:16 #67030Stephen Taylor
SILVER MemberFantastic – that’s worth knowing!
Thank you!
15 July 2025 at 06:00 #67110artig
BRONZE MemberThe service manual is an invaluable aid in reverse engineering the requirements, and most of it could be done using that.
Also there may be some information to be found at https://beomicro.wordpress.com which could be helpful. Including contributions from some of the people who worked on the original development.
15 July 2025 at 20:26 #67181Glitch
BRONZE MemberI agree with artig that the service manual is a great resource for fitting an alternative CPU.
I did a project some time ago replacing the CPU in a Beomaster 6000 Type 2253(?). The project was Arduino based. It was a fun project for me, but I really like doing this kind of thing.
An alternative to re-CPUing is to buy a parts machine that has a good CPU, but is in very poor cosmetic condition. Also check with Danish Sound Parts. They might have what you need. This may be the most cost effective solution, especially if you consider shipping for any parts machines.
Glitch
