Home › Forums › Product Discussion & Questions › BeoSound › Theatre › Sky Q – Theatre Control
- This topic has 3 replies, 2 voices, and was last updated 1 year, 11 months ago by
Millemis.
1 April 2024 at 10:28 #54033
jj07
BRONZE MemberHi All,
I recently setup my Theatre to my LG G2 and sound is amazing and loving the quality. I also have connected via HDMI my SKQ Q Box to the TV. Before the Theatre i could control the volume of my soundbar (SONOS ARC) with the SKY Q remote.
Since the Theatre i am unable to do this and having to either APP or LG Remote.
Any Suggestions on how to overcome this or connection i am doing wrong?
Thank You In Advance,
J
1 April 2024 at 22:47 #54034 Millemis
BRONZE MemberHi J and welcome to the forum
I assume that you want to use the Beoremote One!
I do not know the Sky Q Box – but from reading about the box, it should have an ir receiver.
So it should be possible to connect an ir blaster there and use the B&O PUC solution instead of relying on CEC controlling.
You must connect the box to one of the HDMI ports on the BST and the PUC cable there too.MM
2 April 2024 at 07:34 #54035jj07
BRONZE MemberHi MM
Thank for your response, the BeoRemote One is the next step and will be getting that soon.
I will try the above and see how it goes, hopefully will resolve the issue.
2 April 2024 at 08:40 #54036 Millemis
BRONZE Member -
