Home › Forums › Product Discussion & Questions › BeoGram › RX-2 tonearm wirering
- This topic has 2 replies, 2 voices, and was last updated 1 year, 2 months ago by
Peer Grønnerup.
20 January 2025 at 16:36 #62928
Peer Grønnerup
BRONZE MemberHi,
I had to dismount the tonearm to fix a broken piece of plastic but did not pay attention to the 5 wires which is soldered onto the small board.
How on earth do I make sure i solder them back on correctly?
I quess I cannot just connect them randomly.
Maybe one of you guys now how the 4 sockets are to be soldered?I should then be able to measure which wire is connected to which socket in the end where the stylus is connected.
You must be logged in to view attached files.20 January 2025 at 19:52 #62934 Mark-sfBRONZE MemberObserving from the front and comparing to a clockface:
12 = L
3 = R
6 = LG
9 = RG
You will need to use an ohm meter to identify which wire is connected to which pin.
21 January 2025 at 08:20 #62950Peer Grønnerup
BRONZE MemberThanks Mark 🙂
