Home › Forums › Product Discussion & Questions › BeoVox › Replacement woofer S45/S55
- This topic has 3 replies, 2 voices, and was last updated 1 year, 5 months ago by
Michael Brown.
9 October 2024 at 17:32 #59974
Michael Brown
BRONZE MemberHas anyone experience of these: https://www.bluearan.co.uk/index.php?id=BMA8BR40N&cw=438&cn=Woofer_for_Beovox_S45_8%22_Bass_driver&srsltid=AfmBOop36MVfN3yF-UkLhIz4xy-CQINonGbeyDxKf3FYK8sywAJyf2Oy
If they fit S45 they should fit S55 as physically they are the same width (21cms)
I have a pair of S55 in nice condition. Woofers needs re foaming. Would one of you experts suggest I just replace with these or stay with the generic ones??
14 October 2024 at 21:33 #60149Dillen
ModeratorStay with the original and have them refoamed.
They are unique for these models.
6,4 Ohms if I remember correctly.Size is not everything when it comes to speaker drivers. Look at the list of T/S parameters.
14 October 2024 at 22:12 #60154Michael Brown
BRONZE MemberThanks Martin
Yes 6.4 ohm. I am going to follow your valuable advice
Michael
14 October 2024 at 23:17 #60159Michael Brown
BRONZE MemberMartin Ive read the importance of gluing the magnets; do you apply a bead of glue at the top of the magnet where it slips inside the holding basket??
