Home › Forums › Product Discussion & Questions › BeoVision › Replacement for a dead BV7-40
- This topic has 19 replies, 6 voices, and was last updated 11 months, 1 week ago by
jvezina.
12 June 2022 at 02:33 #35436
stotty1111
GOLD MemberHello all
Looking for suggestions for a replacement for the above tv, it died over 20 months ago, a local repair outfit tried valiantly to revive it all to no avail.
Are there any suggestions as to a good replacement set? I need a screen size around 40″ with hdmi feeds and scart perhaps, I use a BC2 with the screen for DVD playback and a pc for ‘streaming’.
12 June 2022 at 16:11 #35437 pepps
ModeratorHello,
I would keep an eye out for a nice used BV7-40 mk5. I love mine and would certainly get another one if this one packed in, such a gorgeous tv.
Julian
Favourite Product: Beosystem 6500
12 June 2022 at 17:40 #35438 stotty1111
GOLD MemberI live in Brittany, Finistere, nearest B & O vendor is in Rennes, about 150 miles away, followed by Nantes 170, locally ‘stuff’ is a bit like hens teeth, dealerships are also a bit’snooty’ probably because my french is not top line!
Hey ho life’s a bitch!!
14 June 2022 at 02:38 #35439jvezina
GOLD MemberWhat was the problem with the TV exactly? Also which version of Beovision 7 it was?
Thanks,
Jean
14 June 2022 at 06:38 #35440 stotty1111
GOLD MemberIt was a 7-40 Mk6, and had lost picture but the sound was ok!
18 June 2022 at 00:25 #35441jvezina
GOLD MemberWas the problem caused by a backlight failure ?
If yes, it is possible to repair the panel by replacing the defective LEDs (or fluorescent tubes for older screens). There are Youtube videos explaining the procedure. One has to be very careful when dismantling the LCD panel assembly (a flat aluminum box) to not damage the liquid crystal layer and diffuser sheet but this can be done.
The standard repair procedure is to replace the complete LCD panel assembly but if the part is no longer available a last chance repair at the component level can be attempted.
Good luck,
Jean
18 June 2022 at 08:40 #35442 stotty1111
GOLD MemberI don’t know, the repair place did work for 2 x B&O outlets, the technician worked thro’ lots of suggestions from B&O all to no avail!
20 June 2022 at 11:31 #35443 TablokaBRONZE MemberHi Jean,
my 7741 has also trouble with the backlight. Someday during televison the screen went black and never get back again. I sent the TV to my dealer for repairing but he couldn’t fix the problem. So I got the TV back unrepaired.
I read a lot of backlight problems and also watched a lot of youtubes about this topic. In your comment it sounds that you maybe fixed a problem with the backlight by yourself. Do you have any suggestions to dismantling/disassabling the TV in order to get to the LED stribes?
Meanwhile I checked most of the DC voltages of the PCBs compared to the service manual. So far I found only one DC voltage which should be 5V but it was only 3V (PCB03 P005 Pin2).
Thanks in advance Michael
20 June 2022 at 19:42 #35444 YannChrisGOLD MemberHi Stotty,
I’m in Brittany too, near Lorient.
Having some vintage products which need repair, would you tell me where did you send your TV for service?
Please, excuse my intrusion in your thread.
Kind regards,
Yann.
20 June 2022 at 21:16 #35445 stotty1111
GOLD MemberHi Yann,
The ‘sort of’ B&O dealership in Nantes use 111 Services. I say sort of because they deal in a wide range of ‘stuff’, not just B&O!
There is a dedicated B&O outlet in Rennes although my experience was a little negative, the owner got a little short with me because he would not give me any details of 2nd user tv’s. They at that time, 2 years ago, also used 111 Services in Nantes or so I was lead to believe.
I cannot find the relevant telephone numbers, addresses etc as they are filed in an old laptop, if time permits tomorrow or wednesday i will try to find said info!
21 June 2022 at 05:50 #35446 YannChrisGOLD MemberThanks Stotty,
I found the informations about 111 Services and will contact them.
Kind regards,
Yann.
21 June 2022 at 14:55 #35447jvezina
GOLD MemberTabloka wrote:
“Hi Jean, my 7741 has also trouble with the backlight. Someday during televison the screen went black and never get back again. I sent the TV to my dealer for repairing but he couldn’t fix the problem. So I got the TV back unrepaired. I read a lot of backlight problems and also watched a lot of youtubes about this topic. In your comment it sounds that you maybe fixed a problem with the backlight by yourself. Do you have any suggestions to dismantling/disassabling the TV in order to get to the LED stribes? Meanwhile I checked most of the DC voltages of the PCBs compared to the service manual. So far I found only one DC voltage which should be 5V but it was only 3V (PCB03 P005 Pin2). Thanks in advance Michael”
Good morning Michael,
I am following this thread because my own Beovision 7 Mark III (15 years old, now used in my bedroom) has now a backlight problem. The picture is displayed for about 30 minutes, then it starts flickering and goes black, If I just turn the TV off and on, the picture shows again for about 3 seconds and then disappears. I have to let it cool about 15 minutes. After that, I am good for another 30 minutes of viewing. I followed the “normal procedure”: I contacted my local dealer and they will schedule a visit by a technician. If the problem is caused by the backlight and they cannot fix it, I will have to follow the procedure described in Youtube (or ask them to do it)
The service manual describes how to dismantle the TV and remove the LCD panel. But before, checking if the 24 volt supply to the inverter is present is the first step. The BV7 Mk III LCD panel uses fluorescent tubes (CCFL) for the backlight. In my own case, since he TV works for a short time, there is probably a component overheating. Using a component freezer spray to locate it would be the first step. Perhaps it is just a cold solder joint.
These TVs were expensive and top class when new and are in my opinion worth repairing.
Regards,
Jean
21 June 2022 at 15:12 #35448 stotty1111
GOLD Memberare the 2 x vent grills on the underside clear of debris, just a thought!!
21 June 2022 at 18:07 #35449 TablokaBRONZE Member… But before, checking if the 24 volt supply to the inverter is present is the first step…
That is maybe a problem. Because the Mk6 has no CCFL but LEDs there is no inverter but a driver board. And I think when one or more LEDs are not working, the whole panel gets no power (24V) for safety reasons. I am not sure about that but I am quite sure.
As I wrote above: PCB03 P005 Pin2 should be 5V but is only 3V!
Regards Michael
22 June 2022 at 15:20 #35450jvezina
GOLD Member… But before, checking if the 24 volt supply to the inverter is present is the first step…
Regards Michael
There are also Youtube videos explaining how to replace the defective LEDs. I think that 24V is specific to CCFL tubes, the supply voltage for LEDs may be different. Check the service manual for the Beovision 7-55 that has LEDs.
Regards,
Jean
23 June 2022 at 10:21 #35451 TablokaBRONZE Member… Check the service manual for the Beovision 7-55 that has LEDs.
Hello Jean,
I don’t know where to get the Service Manual for the 7-55. In Beoworld.org there is only a user manual available. Any proposals?Michael
26 June 2022 at 16:09 #35452jvezina
GOLD Member… Check the service manual for the Beovision 7-55 that has LEDs.
Hello Jean,
Sorry for the mistake, the service manual is for the BV 11-55 MK IV. I downloaded it and the power supply voltage for the backlight is still 24V, even if the backlight uses LEDs.
Regards,
Jean
26 June 2022 at 16:12 #35453jvezina
I cleaned the two fans with a vacuum cleaner, and unfortunately, the problem recurs. The TV doesn’t come very hot, however.
29 March 2025 at 19:27 #64771Chris Tritschler
BRONZE MemberHello all, I’ve started to repair a Beovision 7-40 (later model with the 4 HDMI inputs). Backlight doesn’t work. I heard there is a surface fuse on the T-con board that’s worth checking but mine doesn’t seem to have that. The next step is to check the elements of the back light which I presume will be LEDs. Further up the thread there is mention of YouTube videos showing how to do this. Can’t find those. Does anyone have links ? Thanks, Chris.
23 April 2025 at 02:17 #65284jvezina
GOLD MemberGood evening,
Sorry for the long delay The videos on Youtube are not B&O specific. First, determine if your TV has a CCFL (fluorescent) or LED backlight. For the Beovision 7, I think panels with LED backlight were introduced starting Mk 5. To be certain, find the Samsung panel model on the sticker on the panel itself and search it on the web.
Then find a video about replacing LED strips or CCFL tubes. If it is CCFL check first if it is an inverter transformer that failed. There are also videos explaining how to check them. In my own case, that was exactly the problem. My dealer kindly gave to me a donor set for parts and I was able to do the repair by replacing the defective transformer as replacement panels are no longer available.
Good luck,
Jean
