Home Forums Product Discussion & Questions BeoVision Removing the upper front panel on a Bang & Olufsen MX8000
  • This topic has 0 replies, 1 voice, and was last updated 4 weeks ago by Samy.
Viewing 1 post (of 1 total)
  • #74311
    Samy
    Hello,
    I am trying to remove the upper front panel of a Bang & Olufsen MX8000, the section at the top front where the LED indicator is located on the right.
    I cannot find any screws holding this part in place from above. It might be secured with clips, but I am not certain. When I carefully pull the panel slightly forward, nothing seems to come loose.
    Before applying more pressure and potentially damaging aged plastic parts, I would like to understand the correct removal method.
    Is the rear cover required to be taken off first?<br data-start=”876″ data-end=”879″ />Are there hidden locking tabs that must be released from inside?
    If anyone has experience with this specific model, I would greatly appreciate your advice.
    Thank you.
    Samy
