Home › Forums › Product Discussion & Questions › BeoRemote › remote interference between 2 I.R eyes
- This topic has 2 replies, 2 voices, and was last updated 1 year, 2 months ago by
Madskp.
17 January 2025 at 19:29 #62844
Andre Bolhoeve
BRONZE MemberGentleman,
I have a few infra-red Eyes in different rooms,
two of them are to close so if I turn the sound up in one room the other will follow or turn on. Except when i keep the remote close to the I.R eye and hold my hand in between.
Is there a way to program the remote for just one I.R eye?
I have a few 1000 remote en a few beo 4 remotes.
Help is appreciated
17 January 2025 at 20:29 #62845Madskp
GOLD MemberI guess that it is link rooms you are talking about?
It is possible to set one of them in Option 4. This way you will need to press Link before the commands to that IR eye, and the other vil not react to it.
With a Beolink 1000 this can be done by pressing Link, 4, Play
Be sure to cover the other IR eye while you do this or that will also be set to that option
18 January 2025 at 09:17 #62850Madskp
GOLD MemberAlso to make things easier in the room that is set to option 4 it is possible to program a BEO4 remote so it as standard put out Link + commands.
Og course if you bring the remote(s) between rooms this will not be an advantage
