Home › Forums › Product Discussion & Questions › BeoLab › Refoaming Pentas. speakerrepairshop or repairyourspeakers
- This topic has 3 replies, 3 voices, and was last updated 2 years, 4 months ago by
Dillen.
29 October 2023 at 08:38 #49918
calania
BRONZE MemberHello. I recently bought a pair of Pentas they are in need of reforming. I am currently considering buying one of theses rubber kits
Are there any difference between theses kits or should I just get whichever one is cheapest? Also how much glue do I need? The kit from Repairyourspeakers comes with 15 ml of glue. Is that enough for all 8 drivers or should I buy one more bottle whiles at it?
Also I saw that Repairyourspeakers sells replacement foam gaskets/rings for 13 € that fit around the mid-range speakers. They claim that they can make quite a difference but I haven’t read about anybody having done it. Are they worth replacing or should I spend the money on something else instead?
29 October 2023 at 18:43 #49919calania
BRONZE MemberDecided to order from Repairyourspeakers and not buy the replacement foam gaskets since, after looking through this forum, I haven’t found a single person mention them so I guess they can’t really make all that much difference.
29 October 2023 at 22:55 #49920 AdamSBRONZE MemberI’ve always used Speakerrepairshop and their products are excellent.
I would not recommend replacing the midrange foam surrounds with rubber. This will change the parameters of the drive units. Stick to foam.
30 October 2023 at 08:38 #49921Dillen
ModeratorThe original gaskets can become immensely brittle.
In these cases it’s nice to have the possibility to simply replace them.Martin
