Home › Forums › General Discussion & Questions › General Discussion & Questions › Recommendation homecinema setup : BL8000+BL7.2+BL3+sub vs BL9+BL7.2+BL3
- This topic has 10 replies, 6 voices, and was last updated 3 months, 1 week ago by
kallasr.
21 October 2025 at 20:17 #70606
Chema Martinez Sanz
SILVER MemberHello everyone!
I am setting up a Bang & Olufsen home cinema system and I’m debating between two speaker combinations. I’d like to know which one you recommend and why, based on your experience.
<ul class=”marker:text-quiet list-disc”>
<li class=”py-0 my-0 prose-p:pt-0 prose-p:mb-2 prose-p:my-0 [&>p]:pt-0 [&>p]:mb-2 [&>p]:my-0″>Option 1: BeoLab 8000 fronts, BeoLab 7.2 center, BeoLab 3 rears, and BeoLab 2 or BeoLab 19 subwoofer
Option 2: BeoLab 9 fronts, BeoLab 7.2 center, BeoLab 3 rears. No subwoofer included.
All speakers are connected to Beosystem 4
What do you think?
Thanks in advance
22 October 2025 at 09:02 #70608 MillemisBRONZE Member2
22 October 2025 at 11:29 #70610Chema Martinez Sanz
SILVER MemberThanks!
I asked the AI a question and its response was exactly the same, even optionally adding a BL19 for even more a cinematic effect..but i think it is not necessary
Chema
22 October 2025 at 16:03 #70611 TignumGOLD MemberHello Chema,
I trust the BL9s are better than the 8000s. But I am not so fond of how they look. So my setup has BL8000, BL7-1 & BL2 with a BeoSystem 3. And I enjoy it every day.
Just to make choices harder 😋.
Wishing you wisdom, regards, Johan.
This reply was modified 3 months, 3 weeks ago by
Tignum.
29 October 2025 at 19:46 #70762Chema Martinez Sanz
SILVER MemberI fully agree with you and may be depend of the use … I’m looking a deeper bass for cinema mode, the 8000 are very good speakers but I think they struggle with low frequencies.
it is a harder choice!
thanks a lot
chema
29 October 2025 at 21:54 #70769DT79
BRONZE MemberHappy with BL 8000 / 7.2 / 6000 / 19 here. I couldn’t abide the appearance of the BL9 and much more convenient to be able to wall mount the 8000s.
31 October 2025 at 16:19 #70828beojeff
BRONZE MemberI have a 7.1.4 Dolby Atmos setup with a Beosound Theatre and six black Beolab 9 speakers. The Lab 9 speakers provide a very even bass distribution for a very immersive experience. I find that the low height of the Beolab 9 makes it blend in with the room and become very inconspicuous. Also, the acoustic lens is the ideal height to be ear level when you’re sitting to watch a movie.
31 October 2025 at 19:28 #70832 MillemisBRONZE MemberThat must be amazing 😻
2 November 2025 at 17:47 #70874Chema Martinez Sanz
SILVER Member<pre id=”tw-target-text” class=”tw-data-text tw-text-large tw-ta” dir=”ltr” tabindex=”-1″ role=”text” data-placeholder=”Traducción” data-ved=”2ahUKEwjlj-utgtSQAxWgVKQEHYseD60Q3ewLegQIBRAV” aria-label=”Texto traducido: Incredible installation!!! Out of curiosity, what function have you assigned to the speakers? Surround, rear, side…?”>Incredible installation!!! Out of curiosity, what function have you assigned to the speakers?
Surround, rear, side…?thanks a lot!
Chema
4 November 2025 at 07:39 #70906beojeff
BRONZE MemberThe Beolab 9 speakers have the roles of front, side surround, and rear. The Beosound Theatre is center channel. Four Beolab 4000 speakers have the height channels and there is a Beolab 2 for the subwoofer. The Beolab 9 speakers and the Beosound Theatre actually have bass low enough to be subwoofers, too.
17 November 2025 at 14:30 #71328kallasr
BRONZE MemberOption 2: BeoLab 9 fronts, BeoLab 7.2 center, BeoLab 3 rears. No subwoofer included.
My choice – I had a Beolab 8000 + Beolab 2 combo before and the Beolab 9 without subwoofer is the better choice.
I suggest a Beolab 7-4 as center speaker (run this in my cinema room with Beolab 4000 as rears).
(In the living room I have a Beolab 7-2 with Beolab 9 (and 8000 as rears) and I feel the Beolab 7-4 in the cinema room is the better choice – not sure if this is due to the room?)
Ralf
