Home › Forums › Product Discussion & Questions › BeoVox › Question About Repairing Beovox S75s
- This topic has 4 replies, 2 voices, and was last updated 1 year, 9 months ago by
AdamS.
24 September 2024 at 05:43 #59328
marcham
BRONZE MemberHi all,
I just picked up a pair of Beovox S75s and am working on restoring them to their proper condition; I already have a capacitor replacement kit from Beoshop on the way to rebuild the crossover.
My question is this: I noticed the sound on one of the tweets is distorted, and I assume the driver has gone bad. Finding a matching driver online looks like it would cost $50+ to obtain one. However, several sellers sell just the silk dome diaphragm at a fraction of the price (see here).
How can I tell if I need to replace the full driver with an old stock spare or if I can get away with just replacing the diaphragm? Also, any tips for testing the drivers to ensure they sound proper?
Thanks!
Favourite Product: Beogram 3000
Signature: - Michael Archambault
24 September 2024 at 12:59 #59342 AdamSBRONZE MemberMy experience with those supposedly “correct” replacement tweeter diaphragms has been very poor. They are usually poor quality and the last ones I bought had the wrong diameter voice coil and had the lead-out wires in completely the wrong place for the dome they were supposed to be replacing.
To cap it all, when I returned them for a refund, they allegedly “got lost” in the post.
I would buy a complete correct replacement tweeter. The S75s are very good so definitely worth it.
24 September 2024 at 20:01 #59361marcham
BRONZE MemberThanks for the advice, Adam.
I tested the speakers again this morning with a tone generator, and both tweeters seem to rattle at different frequencies. I can also clearly tell the sound is duller on one of them. Do you think there is any chance this could all be fixed with new caps? Or does rattle generally only occur when the driver has gone bad?
I’ll be replacing the caps either way, as I’m sure it will help with the dull factor, but it would be nice if it fixed the issue instead of needing to drop an additional $100+ on tweeters pulled from another S75.
25 September 2024 at 03:12 #59370marcham
BRONZE MemberJust tested the ohms rating of each driver.
Looks like the tweeters are both shot… Or ridiculously low ohm.
Speaker 1
Tweeter – .5
Top – 5.6
Middle – 7.2
Bottom – 3.5
Speaker 2
Tweeter – .6
Top – 5.6
Middle – 7.1
Bottom – 3.4
Guess I’m spending a bit more cash.
25 September 2024 at 14:19 #59393 AdamSBRONZE MemberYes, sadly your tweeters have had it – bad luck!
A low resistance reading suggests that the coil has probably overheated and individual turns of the coil wires have melted together (which would also cause the rattling you’re hearing), so they won’t be salvageable, sadly.
