Home › Forums › Product Discussion & Questions › BeoGram › Play in DIN cable Beogram 3000
- This topic has 4 replies, 2 voices, and was last updated 3 years, 2 months ago by
hejsam.
8 December 2022 at 08:16 #41357
hejsam
BRONZE MemberHi,
I have a Beogram 3000 turntable connected to a Beomaster 3000, it has the original 7-pin data link cable that has worked properly for years.
But now it seems like there is a play in the cable and the sound gets laggy/faints.
If a fiddle a bit with the cable where it connects to Phono input on the Beomaster it makes it better/worse.
Could I troubleshoot this somehow? How easy is it to replace the cable?
11 December 2022 at 18:34 #41358Gravity Graham
BRONZE MemberIt sounds as if the phono plug has a bad/dry joint.
I would open up the 7 pin DIN from the BeoGram, and check the soldered connections.
I have found that if I warm up the plastic sleeve on the plug, that it can be slowly pulled back to give you a better idea. Otherwise, I suggest getting a new 7-pin DIN and cutting the sleeve off, make a note of which wire is on which pin, then simply replace the plug with the new one. (Remembering to slide the sleeve onto the cable first – been there and made that error in the past !)
Hope this helps – GrahamLocation: Cornwall, UK
13 December 2022 at 20:32 #41359hejsam
BRONZE MemberThank you @gravity-graham this is how the wire looks, I have no idea how they should look? Is there a scheme you can see somewhere?
13 December 2022 at 20:41 #41360hejsam
BRONZE MemberThere is a blue cable that is not connected to anything and it looks to be at least 2 pols that is not connected, could this be the problem?
3 January 2023 at 14:13 #41361hejsam
BRONZE MemberAny help?
