Home › Forums › Product Discussion & Questions › BeoLab › Penta MkII display issue
- This topic has 5 replies, 4 voices, and was last updated 1 year, 1 month ago by
Die_Bogener.
18 October 2024 at 18:16 #60251
David Penny
BRONZE MemberHi
I have recently been given a pair of Penta MkII speakers. Model 6622.
They are amazing and I already love them.
However, the LCD display on one is weirdly upside down. The other one has no display at all.
Should both displays be working together?Should I try to fix the upside down display or just leave it well alone? It is quite annoying, but quirky, I suppose.
18 October 2024 at 18:39 #60252Glitch
BRONZE MemberThe display was most likely installed upside down when a previous owner worked on the speakers and didn’t have a way to test the displays. It should be an easy fix. Carefully remove the plastic display cover. The plastic will be brittle (new replacements are available if needed). IIRC, the display is held in by 4 screws. Remove, flip, reassemble, and enjoy your new Pentas.
Glitch
19 October 2024 at 15:40 #60268Glitch
BRONZE MemberThe other one has no display at all.
The easiest way to start debugging this is to swap components between the working and non-working speaker. 1) PL cables and connections, 2) amplifiers, 3) check the soldered wires on the inside of the display connector on the bottom plate of the speaker, 4) display boards.
Glitch
9 January 2025 at 16:34 #62444 filip_kbhBRONZE MemberIf the other one has no display at all, please check the switch at the bottom of the speaker where you can turn the display off. I think it says Audio/Video – and the idea was to be able to turn of the display in a dedicated cinema room.
10 January 2025 at 16:39 #62500David Penny
BRONZE MemberHi
Thanks for your message. I have already tried that but have just tried it again and still no display, so I think I need a new unit.
16 January 2025 at 15:00 #62799Die_Bogener
BRONZE MemberThe orange display has a 7805 5V Power regulator chip, they become pretty hot for a long time. Check it, some of them are simply dead.
