Home › Forums › Product Discussion & Questions › BeoLab › Penta Display removal and repairs
- This topic has 12 replies, 3 voices, and was last updated 3 years, 9 months ago by
david656.
6 June 2022 at 08:04 #35350
lightitup
BRONZE Member- Help needed, how is the display and display PCB removed for repair. Any assistance would be greatly appreciated. I’ve re-foamed all mids and have main amps ready recapping etc. My repair kit came with the caps for displays, so may as well??
- I also worked out a useful hack to clean up mid.
sped up the process 10fold
10 June 2022 at 06:30 #35351jesnystrup@gmail.com
BRONZE MemberI am in the same proces ..What is your hack to clean ,And where did you buy the repair kit
with the caps for display ..i search everywhere and cant find any that sell them.
Mfg jes
10 June 2022 at 12:30 #35352 lightitup
BRONZE Member“Beolab Penta Amplifier capacitor and service kit” from Beoparts included the extra caps for the displays.
This long, but thorough video is a must
https://www.youtube.com/watch?v=psY_RV1NjHM&t=447s&ab_channel=TheRetroBristolian
from New Zealand is pretty expensive to get speaker parts and electronics from UK or USA so I sourced rubbers from Aliexpress, but if I did them again id probably use genuine as they have the inner angle set right.
My Hack was as pictured- use a plastic lid from a jar of screws as a bath, fill it with acetone, methanol or alike. It holds the speaker clear of the fluid except for the rim, Also if you know of anyone that has a distillery ask them for the Foreshot it’s usually thrown away and works a treat.
10 June 2022 at 19:11 #35353jesnystrup@gmail.com
BRONZE MemberSuper ..Thank you .
11 June 2022 at 04:07 #35354 lightitup
BRONZE Memberbeopart SKU:SK-003 ?
20 June 2022 at 14:06 #35355david656
BRONZE MemberDamn it didn’t post my message.
‘lightitup’ thanks for recommending my video – it means a lot to think others are getting value from it.
I saw this thread and couldn’t resist jumping in with a display recap video to help out.
Thanks,
24 June 2022 at 22:44 #35356 lightitup
BRONZE Member- Thanks again David you gave me the courage to
pull a bit harder ? the Penta 1 doesn’t have the screws the first display cover is the same the next screen cover also unclips with 3 small pegs “brittle” then the digit board hinges up slightly and unplugs downward and then the other boards slide and unplug the same or I suppose the whole thing should just pull out as one, but you would be relying on the three brittle clips ?
thanks again regards Brad
25 June 2022 at 01:20 #35357 lightitup
BRONZE MemberUpdate Penta 1 display (that I have aren’t covered by the SK-003 recapp kit??from beoparts,
needed are 2 of each 16v 2200uf
16v 10uf
10v 47uf
25 June 2022 at 11:30 #35358david656
BRONZE MemberThanks for the posts! Martin never claimed his kit covers the MK1 displays, I’m not sure why he doesn’t have a kit for those.
But that’s really good photos to see! I’ve got a MK3 screen here I’m going to do a quick vid on probably, so then we have videos of MK2 and MK3 and your photos of MK1!
It’s surprising how different those MK1 displays are in technology. I’d love to see more pictures of the overlay piece that sits in front of the segment displays.
If you can get in there, could you take a snap of the big IC chip, I’d love to know if that chip remains the same across all 3 which I ‘think’ it does.
25 June 2022 at 21:46 #35359 lightitup
BRONZE Member25 June 2022 at 22:23 #35360 lightitup
BRONZE MemberThanks, David for your enthusiasm. it is nice to know someone is far more interested them than my wife, hahaha. So as you will notice definitely not a perfect match, from the other signs of damage also I assume one of the displays has been fully replaced, with completely different components and display lens. Ohh and if you’re wondering I didn’t have any Axial Caps 2200uf so had to improvise, for now, the existing ones were well out 2605uf and 1815uf, I might look at a mkII display upgrade in the future, also I’m not sure whether to pair them with the 9500 or my new acquisition Beovision Avant 32RF (i need to claim another room in the house first) regards Brad
25 June 2022 at 22:35 #35361 lightitup
BRONZE MemberJust an addition in case anyone else is crying over broken Amber covers, as they are so brittle, they do glue nicely (well enough) back together with the “bondic UV” still working on the holding pegs wont be as easy to hide like the smoked covers.
3 July 2022 at 08:24 #35362david656
BRONZE MemberVery VERY interesting! Incredible to see 2 different front face plates for the Mk1 displays! Also interesting to see the ‘big chip’ it is not the same as the MK3 I’ve checked, and I suspect that is the same as the MK2 (although I haven’t checked that yet. As I said on your Avant post, reach out directly I’d enjoy having a proper chat 🙂
Thanks,
