Home › Forums › Product Discussion & Questions › BeoRemote › Pairing Beoremote One with Beocenter 2300
- This topic has 2 replies, 2 voices, and was last updated 5 days, 5 hours ago by
Joakim.
19 April 2025 at 20:02 #65181
Joakim
BRONZE MemberHi, my Beoremote One is paired with ย Beovision 11-40, and I would also like it to work with my BeoCenter 2300. The Br1 manual has a section for this but it is not easy to understandโฆ
- I have added it as a โBeo4 Productโ to the BR1 LIST, but I then also need to set up the BC2300 to the right Option (1, 2, 5 or 6 according to the BR1 manual). How do I know which one??
- When โpairingโ, should the BC2300 be turned on or doesnโt it matter?
The BC2300 is currently controlled ny a Beo4 remote, and I want that to keep working in addition to the BR1 if possible.
Location: Gothenburg Sweden20 April 2025 at 15:34 #65194BRONZE MemberIf the BC2300 works now with your Beo4, you do not need to change its Option (probably #1). As you have read, you need to set up the Beoremote One to send IR commands. ย There is no “pairing” of the remote to Beo4 Audio devices; pairing is a Bluetooth concept. ย It just spits out the IR codes and whatever can see them reacts. ย Thus your Beo4 will continue to work with the 2300. ย (I *only* use my BR1BT in IR mode, so I don’t know if it switches back and forth between IR and BT automatically for MUSIC vs. TV. ย Hopefully someone else will advise.)
This reply was modified 5 days, 11 hours ago by
20 April 2025 at 21:50 #65200Joakim
BRONZE MemberThanks a lot, I will try to make the BR1 send signals to โBeo4 Audioโ then, there is a section on that in the manual.
