Home › Forums › Product Discussion & Questions › BeoRemote › Pairing Beoremote One with Beocenter 2300
- This topic has 2 replies, 2 voices, and was last updated 11 months, 2 weeks ago by
Joakim.
19 April 2025 at 20:02 #65181
Joakim
BRONZE MemberHi, my Beoremote One is paired with Beovision 11-40, and I would also like it to work with my BeoCenter 2300. The Br1 manual has a section for this but it is not easy to understand…
- I have added it as a ”Beo4 Product” to the BR1 LIST, but I then also need to set up the BC2300 to the right Option (1, 2, 5 or 6 according to the BR1 manual). How do I know which one??
- When ”pairing”, should the BC2300 be turned on or doesn’t it matter?
The BC2300 is currently controlled ny a Beo4 remote, and I want that to keep working in addition to the BR1 if possible.
20 April 2025 at 15:34 #65194 trackbeoBRONZE MemberIf the BC2300 works now with your Beo4, you do not need to change its Option (probably #1). As you have read, you need to set up the Beoremote One to send IR commands. There is no “pairing” of the remote to Beo4 Audio devices; pairing is a Bluetooth concept. It just spits out the IR codes and whatever can see them reacts. Thus your Beo4 will continue to work with the 2300. (I *only* use my BR1BT in IR mode, so I don’t know if it switches back and forth between IR and BT automatically for MUSIC vs. TV. Hopefully someone else will advise.)
20 April 2025 at 21:50 #65200Joakim
BRONZE MemberThanks a lot, I will try to make the BR1 send signals to “Beo4 Audio” then, there is a section on that in the manual.
