Home › Forums › BeoWorld around the world! › Dutch › Ouverture turn on crackling
- This topic has 1 reply, 2 voices, and was last updated 9 months ago by
Peter Fraser.
1 June 2025 at 15:31 #66094
JH
BRONZE MemberHello everyone,
I just registered here in the forum, because I’m having a problem with my old Ouverture (Type 2631 SW2.1) + Beolab (2 x Type 6201).
When I turn the system on from standby, there’s a very loud crackling noise, and the sound output sounds noisy and very quiet.
Whether playing CDs or tuners.
I’ve already opened the system and checked for the usual suspects (electrolytic capacitors), but I couldn’t find anything wrong.
Do any of you have any ideas?
Thank you for your help!
Jörg
You must be logged in to view attached files.Location: Wuppertal
Favourite Product: Ouverture
26 June 2025 at 09:01 #66665Peter Fraser
ModeratorHello,
I would first eliminate the speakers.
Try the system with just one speaker plugged in and see if the problem persists.
The cables may also cause this issue.Does the problem also occur when using headphones?
Kind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics -
