Home › Forums › Product Discussion & Questions › BeoSound › Ouverture and 1656
- This topic has 1 reply, 2 voices, and was last updated 2 years, 6 months ago by
Madskp.
1 September 2023 at 10:40 #48600
LeoM
BRONZE MemberAm new to this forum, forgive me if I ask a double question.
I got a BeoSound Overture from my mother, bought 2 passive speakers from Kenwood, but am still looking for an amplifier. I read an offer for a 1656. Is that a good choice? The intention is to listen to the system in 1 room only.
Thanks in advance for the reply
2 September 2023 at 06:50 #48601Madskp
GOLD MemberHello and welcome to the forum
The 1656 Beolink Passive should work just fine for your purpose. One important note is that you need a fully wired powerlink cable between the ouverture and the 1656 for it to work.
you might also be able to find the box named as ML-MCL converter with a different type number. It is the same box, it can just be used for other types of setups also. If an Ir eye is bundled with a ML-MCL converter you wont need that in your setup.
hope this is helpfull
