Home Forums Product Discussion & Questions BeoLink On/off macro for BeoLink Gateway
  • #62852
    christoffer.betzer
    Hello.
    I just have a question that I hope someone can help with.
    I’m playing around with getting a BeoLink Gateway on my system at home.
    Can I make a macro where I can switch a light group on and off using the same button on my BeoRemote One (eg green)…?
    Thanks in advance
    carolpa
    Hello. I just have a question that I hope someone can help with. I’m playing around with getting a BeoLink Gateway on my system at home. Can I make a macro where I can switch a light group on and off using the same button on my BeoRemote One (eg green)…? Thanks in advance
    Goto “Recources”
    Select “Virtual sources”
    Select the zone; choose a name; select type: “virual button”
    Goto your Macro as shown
    Add the second event “your_area/your_zone/BUTTON/your_button” with the event PRESS
    #63024
    tb59427
    Member
    Also, just in case you might control your lights (and home for that matter) via homeassistant: there’s a cool plugin for homeassistant that effectively receives all the traffic on the ML bus. Each event on the ML bus creates a trigger in homeassistent. With this you can easily program actions in homeassistant which catch beo4 key presses and trigger whatever you want in homeassistant.
    cheers
    -tb
