Home › Forums › Product Discussion & Questions › BeoCenter › On connecting a Beomaster 1900 with a set of Beolab Penta
- This topic has 0 replies, 1 voice, and was last updated 1 year, 4 months ago by
Frederik G.
18 November 2024 at 16:12 #61018
Frederik G
BRONZE MemberHi there!
I have been lucky enough to acquire both a working Beomaster 1900 as well as a set of Beolab Pentas (Type 6631, MKIII). These I am currently running with a Pioneer SA-508 using an Attenuated Convertor kit (similar to this one: https://soundsheavenly.com/line-in-connection/33-power-amplifier-to-beolab-line-in-attenuated-convertor-kit.html) running into the Line-In.
I suppose I can use the two 2-pin DIN output from the 1900, split them into positive and negative, and then connect them to the Attenuated Convertor which outputs a Line signal I currently use.
Is there a smarter way to connect them to the 1900? Looking for any kind of input, and thanks in advance!
Best regards,
Frederik
