Home › Forums › General Discussion & Questions › General Discussion & Questions › Non B&O TV with B&O
- This topic has 5 replies, 6 voices, and was last updated 2 years ago by
Millemis.
30 March 2024 at 06:39 #53927
sorenfelden
BRONZE MemberI am looking to buy and pair a non-B&O TV (possibly an LG) with Beolab 18/19 speakers, controlled by a BeoOne remote.
The Stage is beautiful, but cannot connect to other speakers, so that’s a no go. I don’t like the design nor price tag of the Theatre, so that’s also a definite no go.
Is there any other way of simply connecting the LG TV with the speakers and remote? I read that the latest LG TVs have or will have native support for BeoOne – is that true?
30 March 2024 at 07:37 #53928TinusAMS
BRONZE MemberHi,
I think this topic will be helpful: https://forum.beoworld.org/forums/topic/control-lg-tv-with-beoremote-one/
I have not read about the native support, that could change things. I have a LG G3 which still needs a hardwired connection between the tv and an Stage or Theatre to use BR1.
30 March 2024 at 08:10 #53929
NQVHNWIBRONZE MemberThe Beoconnect Core will do what I believe you want…..
HDMI to BC-Core. Powerlink out to your Beolabs?
You need to check with your Dealer but I think you will be able to load the Beo/LG App in the LG and get control??
30 March 2024 at 09:02 #53930Sandyb
BRONZE MemberI dont think the new Core allows the BR1 usage / integration that you get with a Stage/Theatre + LG.
Also, the new Core can only connect a pair of BL’s, i.e not a sub in addition.
30 March 2024 at 15:36 #53931Stan
BRONZE MemberYou can still daisy-chain a BL2. There is just no dedicated sub out.
30 March 2024 at 19:10 #53932 Millemis
Miki should be able to answer that question in the next Beotalk episode.
After all he has and has had the BCC for a while now.MM
