Home › Forums › Product Discussion & Questions › BeoVision › No Bluetooth on Beovision Avant 75
- This topic has 7 replies, 2 voices, and was last updated 3 years, 9 months ago by
Millemis.
27 May 2022 at 11:39 #35061
cyberc
BRONZE MemberI’m trying to activate or use Bluetooth on my beovision avant 75.
I have browsed through the menues but I can’t seem to find the Bluetooth menu?
I read the instruction manual and according to that I need to push “Home” and select “ Trådløs og netværk” I don’t have that I only have “opsætning” and then “network” but in there, there aren’t any Bluetooth menu. I’m sort of hoping that it’s because it’s not activated yet?
what am I missing since my tv doesn’t have a Bluetooth menu?
To add last year my tv got the main board replaced due to a known error which caused it to malfunction.
Regards.
28 May 2022 at 18:42 #35062 MillemisBRONZE MemberSince you write about ‘a changed mainboard’, I assume that you have a MK1 version.
In that case it is very easy to answer – altough you might not be pleased – there is no bluetooth support whatsoever on that tv!
28 May 2022 at 19:25 #35063cyberc
BRONZE MemberSince you write about ‘a changed mainboard’, I assume that you have a MK1 version. In that case it is very easy to answer – altough you might not be pleased – there is no bluetooth support whatsoever on that tv! MM
Thanks for your reply.
If the tv doesn’t support Bluetooth why does the instruction manual refer to how it is used etc?
28 May 2022 at 19:38 #35064 MillemisBRONZE MemberCould you please state which version (MK1 or NG), you have.
Are you sure that you refer to the right user guide?
28 May 2022 at 19:39 #35065cyberc
How or where do I see that?
28 May 2022 at 19:52 #35066 MillemisBRONZE MemberYou could do a (google) search for Avant MK1 and Avant NG.
If you’d post a picture of the main menu, we’d know —— the MK1 has the menus on the left side of the screen and the NG has the menu items horizontal at the bottom with the access to the ‘smart’ functions etc.
Which remote do you use?
28 May 2022 at 20:17 #35067cyberc
BRONZE MemberYou could do a (google) search for Avant MK1 and Avant NG. If you’d post a picture of the main menu, we’d know —— the MK1 has the menus on the left side of the screen and the NG has the menu items horizontal at the bottom with the access to the ‘smart’ functions etc. Which remote do you use? MM
here is a picture of the main menu.
28 May 2022 at 20:42 #35068 MillemisBRONZE MemberThat is definitely a MK1 (the best ?).
Means no bluetooth there!
You could however, use the A/V input with the right adapter cable to connect a BT receiver of some kind…
……or even better get a Essence MK2 or a Core and (link/) integrate that with the Avant. This way you’d have BT and more turning the BV on when you start the playback.
