Home › Forums › General Discussion & Questions › General Discussion & Questions › nl/ml converter and gateway with beosystem 4
- This topic has 2 replies, 3 voices, and was last updated 24 minutes ago by
carolpa.
7 February 2026 at 08:37 #73339
cameron trivett
BRONZE MemberI’m trying to integrate a beosystem 6500 with a beosystem 4. They’re both in the same room. I have an NL/ML converter and a be0link gateway. Can anyone help me in the best way to wire these together. Thank you
7 February 2026 at 09:24 #73340 MillemisBRONZE MemberYou could start reading this – especially the section on NetworkLink:
7 February 2026 at 13:45 #73353 carolpa
You’ll need also a T1611 converter.
If you do not have speakers connected to the Beosystem 6500; connect like this..
Beosystem 6500 Powerlink & Datalink connected to the T1611
T1611 – ML connected to the NL/ML converter (BLC)
BLC – LAN connected to router/switch
Beosystem 4 – LAN connected to the SAME router/switch.
Note: unplug the Beosystem 4. Beosystem 6500 the BLC and the T1611 from the mains. Make all the PL, DL, ML & LAN connections. replug the Beosystem 6500, the Beosystem 4 and the BLC. if everything is up and running plug in the T1611 to the mains.
Set the BLC to ASlave; check ML enable box
In the Setup – Beoconnect menu of the Beosystem 4 set the Beosystem as primary product. Accept also the question about sharing speakers.
Now it should be possible to play Beosystem 6500 sources on the Beosystem 4.
