Home › Forums › Product Discussion & Questions › BeoSound › Theatre › New product launch – beosound theatre?
- This topic has 1,346 replies, 114 voices, and was last updated 7 months ago by
Sven-Inge Neij.
1 October 2022 at 18:58 #37402GOLD Member
Basicly you can do just like you can with all previous (after BV7/BSys3) systems =
You can give any speaker any role you’d want to!
In case of having two capable speakers, that are assigned as FR and FL, you’d probably be best off with using the L/C/R of the Theatre as one big C/center speaker.
If might also be interesting to try using the Theatre as L/C/R and the – in your case BL18’s – as LWide and RWide. That might be good in certain rooms.
I expect that we will soon read more about this from Geoff Martins pen.
Will be interesting too how the up- and sidefiring speakers can be used…….especially when one has no native Atmos track playing.
(My guess is that they will be used for the speakers/all speakers to adapt better to the room……after a calibration has been done).MM
Location: Flensborg————Danmark1 October 2022 at 23:09 #37403Mark
FOUNDER MemberI am now going to have a similar setup like Severed hand… After ordering my Theater I had to take both of my Beolab 14 subwoofers in for repair for different problems. I received a less than optimistic prognosis for their repair which got me to rethink my layout. After some careful consideration, I decided to buy a pair of Beolab 18’s, and then talked into a Beolab 19. I already have a pair of Beolab 17’s that I will use for the rears. Along with the Theater, I think this will give me a completely different sound environment than I have now. I was wondering how to use the Theater since I will have the 18’s up front and fairly near the Theater. Hearing that there is a LWide and a RWide channel available could prove really interesting! I will have a lot of experimenting to do.
2 October 2022 at 05:39 #37404BRONZE MemberI wonder is since I have a small room it makes sense to tell both the BL18 and the side firing speakers to be the front L&R. Or maybe that will just muddy the sound. I think it’s going to take a lot of experimenting to see how it bounces off the walls.
I look forward to the up firing ones to see how well they work as virtual highs.
Since the BL18’s will be about 1M from the edge of the TV does anyone have any suggestions as to the best use of the theatre speakers would be?
Location: Toronto, Canada2 October 2022 at 10:41 #37405NQVHNWI
FOUNDER MemberThis is an interesting question. Im going to have a look soon at a Theatre to see if it is worth it. I dont like the stand options and I am still “burnt” from the uselessness of the Eclipse
- Specialised LG Panel which no longer available
- The LG Interface and operating parameters rather than pure B&O which could be more of the same.
- The Soundbar of the Eclipse cannot keep up with the BL90s. Better to mute the Soundbar and use BL90 phantom. Works much much better. Will Theatre keep up?
The marketing seems to suggest yes and seems to indicate it has a DSP which can maximise desirable sound dispersion. The question would have more to do with distance/direction and quality of the front loudspeaker vs the Theatre. I think a pair of BL90’s as fronts and 1.5-2m apart from either side of the Theatre should (according to marketing) interact better than say Bl4000/BL17/BL3, 0.5m apart from a Theatre.
2 October 2022 at 12:19 #37406GOLD MemberB&O was at Cedia 2022 with the BS Theatre.
Lousy sound quality in the video, but informative.
Location: Flensborg————Danmark3 October 2022 at 11:56 #37407beojeff
BRONZE MemberThe Beosound Theatre user guide is now available on the B&O site.
3 October 2022 at 13:27 #37408FOUNDER MemberIt’s funny that there (with one or two exceptions) was no mentioning of a required ethernet connection between tv and soundcenter, as we know it from the previous LG-based Beovisions in the new install videos. Or was what we saw not LG-tv’s, but another brand, just a generic tv? We still need to know how the unit (including the LG-tv functions) is controlled with a Beoremote One. MM
I visited the demo 2 or 3 weeks ago and asked about this.
The LG still have to install a B&O app. But it is a downgraded version of the LG app when you compare it the Harmony’s sound center version.
The app in the LG store is needed to get the remote 1 working.3 October 2022 at 15:34 #37409BRONZE MemberMy god the Halo was updated for compatibility with the theatre but it can only control music functions. I wonder if volume control while watching TV is even an option.
Location: Toronto, Canada3 October 2022 at 15:53 #37410FOUNDER MemberIf not, then it will be just a matter of time, I guess.
You can control the Harmony with its soundcenter with the Halo.3 October 2022 at 19:46 #37411GOLD MemberIt’s funny that there (with one or two exceptions) was no mentioning of a required ethernet connection between tv and soundcenter, as we know it from the previous LG-based Beovisions in the new install videos. Or was what we saw not LG-tv’s, but another brand, just a generic tv? We still need to know how the unit (including the LG-tv functions) is controlled with a Beoremote One. MM
I visited the demo 2 or 3 weeks ago and asked about this. The LG still have to install a B&O app. But it is a downgraded version of the LG app when you compare it the Harmony’s sound center version. The app in the LG store is needed to get the remote 1 working.
That is true.
There is (at least as of now) nothing you can do there but have a link to the app store for the Bang & Olufsen app in order to get all parts connected.
I suppose once you have programmed all (Speaker Groups, listening positions, stand positions, preferred apps of the tv in the remote, integration with other Beolink products in the house, PUC programming, the MyButtons etc), you won’t need the app on the mobile device much…..that is if you choose the combination with the LG-tv.
Some may be ok using the mobile app and the original remote of a different tv – personally I would not want to, but it is doable.
Location: Flensborg————Danmark3 October 2022 at 20:28 #37412GOLD MemberHi Beoworlders,
This video explains how to make sure you hear Beosound Theatre at its best, so you can hear what it is really capable of when you have an in-store or at-home demo…
I hope you find it helpful.
Kind regards, Steve.
Location: The cable workshop, EnglandFavourite Product: Beosystem 72-23Signature: Cables, friendly advice and great ideas for connecting Bang & Olufsen! Ask any questions at https://soundsheavenly.com to get the best from your B&O! Please visit my B&O YouTube channel at https://www.youtube.com/soundsheavenlycablesMy B&O Icons:4 October 2022 at 15:50 #37413beojeff
BRONZE MemberThere have recently been more entries added to the FAQ. There is now an explanation about setting up and using the PUC. I had wondered how we would access some functions in the Menu with the menu overlay being gone since the video is now passthrough. According to the FAQ, pressing LIST on the Beoremote One will show those functions that would have otherwise been in the menu overlay.
4 October 2022 at 15:57 #37414BRONZE MemberMy dealer is telling my the 65″ version with the motorized stand is due in Nov. Gonna be a long wait 😀
My G2 is arriving today though and gonna sit in the box for a while 🙁
Location: Toronto, Canada4 October 2022 at 16:11 #37415FOUNDER MemberThat’s the same as with the Eclipse and Harmony.
The Beoremote One BT act as an 2 way remote. Options are send into the BR1BT.
Under listing of TV/Music you will get the different sources. And under List you’ll get the different options/settings.4 October 2022 at 16:32 #37416beojeff
BRONZE MemberThat’s the same as with the Eclipse and Harmony. The Beoremote One BT act as an 2 way remote. Options are send into the BR1BT. Under listing of TV/Music you will get the different sources. And under List you’ll get the different options/settings.
My biggest concern is that we get all of that 2-way functionality with the Beoremote One paired with the Theatre without an LG screen.
5 October 2022 at 16:42 #37417GOLD MemberHi Beoworlders,
Sorry for the delay, I am pleased to confirm that the USB audio input adapter for Beosound Theatre is now available – so now you can connect any audio system, Beosound or Beogram to play through your new soundbar!
Location: The cable workshop, EnglandFavourite Product: Beosystem 72-23Signature: Cables, friendly advice and great ideas for connecting Bang & Olufsen! Ask any questions at https://soundsheavenly.com to get the best from your B&O! Please visit my B&O YouTube channel at https://www.youtube.com/soundsheavenlycablesMy B&O Icons:5 October 2022 at 21:36 #37418frankmj
BRONZE MemberHi Beoworlders, Sorry for the delay, I am pleased to confirm that the USB audio input adapter for Beosound Theatre is now available – so now you can connect any audio system, Beosound or Beogram to play through your new soundbar!
https://soundsheavenly.com/tv-misc/191-usb-c-audio-input-adapter-for-beosound-theatre-ref-6271374.html Kind regards, Steve.
Hi Steve, I’ve tryed to connect my BS 3000 to a BS A1 2. Gen. using a Powerlink to minijack adapter and a jack to USB-C converter. But i can’t get any sound out of the BS A1. If I skip the jack to USB-C and just connect my headphones to the minijack, the music plays in my headphones. Is there a difference in the BS Theater and the A1 USB-C connections?
Kind regards, Frank
Location: Elsinore, Denmark6 October 2022 at 07:44 #37419GOLD MemberHi Frank,
The A1 doesn’t support an analogue audio input via USB, only the Theatre supports this.
The second generation A1 doesn’t have any cabled audio input, only the first generation A1 has this via a 3.5mm minijack socket.
Location: The cable workshop, EnglandFavourite Product: Beosystem 72-23Signature: Cables, friendly advice and great ideas for connecting Bang & Olufsen! Ask any questions at https://soundsheavenly.com to get the best from your B&O! Please visit my B&O YouTube channel at https://www.youtube.com/soundsheavenlycablesMy B&O Icons:6 October 2022 at 09:03 #37420frankmj
BRONZE MemberHi Frank, The A1 doesn’t support an analogue audio input via USB, only the Theatre supports this. The second generation A1 doesn’t have any cabled audio input, only the first generation A1 has this via a 3.5mm minijack socket. Kind regards, Steve.
Thanks Steve, but that’s not what B&O write in their Specs:
CONNECTIVITY
CollapseBluetooth Version
5.1
Inputs and Outputs
USB-C for charging, speakerphone and streamingKinds regards
FrankLocation: Elsinore, Denmark6 October 2022 at 11:21 #37421GOLD MemberHi Frank,
That is not an analogue audio connection on the A1, it is a digital data interface to allow the A1 to be used as an external USB interface when connected to a compatible computer. The analogue audio compatibility of the Theatre USB-C connection is different, this is a specific re-allocation of the D+ and D- data interchange pins to allow for a stereo audio input. No other B&O products support this analogue audio input via USB-C as far as I am aware.
Location: The cable workshop, EnglandFavourite Product: Beosystem 72-23Signature: Cables, friendly advice and great ideas for connecting Bang & Olufsen! Ask any questions at https://soundsheavenly.com to get the best from your B&O! Please visit my B&O YouTube channel at https://www.youtube.com/soundsheavenlycablesMy B&O Icons: -
