Home › Forums › Product Discussion & Questions › BeoSound › Theatre › New product launch – beosound theatre?
- This topic has 1,346 replies, 114 voices, and was last updated 7 months, 1 week ago by
Sven-Inge Neij.
17 December 2022 at 10:59 #37822
DHA
BRONZE MemberI would be interested in knowing if the Shape can be used as a rear option with the theatre. My question is connectivity, can it be used wireless (I assume via the Core)
17 December 2022 at 11:10 #37823PhilLondon
Currently the Beosound Theatre can only connect to other speakers via Powerlink (wired or wireless). So you cannot use other speakers connected to a Beosound Core, as this would use the Network Link protocol.
You could probably if you used a Wireless Receiver instead of the Core.
There’s some talk that you’ll be able to connect some Mozart speakers as rear speakers, but Core isn’t Mozart.
17 December 2022 at 11:44 #37824DHA
Currently the Beosound Theatre can only connect to other speakers via Powerlink (wired or wireless). So you cannot use other speakers connected to a Beosound Core, as this would use the Network Link protocol. You could probably if you used a Wireless Receiver instead of the Core. There’s some talk that you’ll be able to connect some Mozart speakers as rear speakers, but Core isn’t Mozart.
Thank you
17 December 2022 at 14:22 #37825Razlaw
BRONZE MemberI can edit speaker roles on included speakers, but the Receiver 1 speakers get greyed out after room sense and I cannot select them to do anything with them. Also, when editing roles, I only get one role for a subwoofer: rear(or possibly back) center. I see that you get THREE possible roles for subwoofers in the back of the room. This is odd.
What version of the app are you using? I have 4.5.0.22121373323.
17 December 2022 at 14:35 #37826Razlaw
BRONZE MemberI just ran room sense again and here are the steps. Run room sense. Click next and give the group a name. Click done. And done again after the experience Theatre option. Back on Home Screen select the group you just created. Click three dots top right corner and go in to advanced settings. That should bring up a menu that says the Receiver 1 is not included but it will not be greyed out. Click on Receiver 1 and then select Role and then select position. Touch outside the position selection mini screen to close it and then touch the back arrow top left corner. Then scroll to the bottom of the page and touch continue which should take you back to the Home Screen. The Receiver 1 should be saved now in that group and active.
17 December 2022 at 14:49 #37827Razlaw
BRONZE MemberDeleted…misread post I was replying to.
17 December 2022 at 16:34 #37828beojeff
BRONZE MemberRazlaw,
When I click on the 3 dots, I only get two options: Duplicate or Delete. I don’t get an option to choose Advanced.
My B&O app is version 4.4.2.22112852170. Is your B&O app a beta version?
17 December 2022 at 17:01 #37829Razlaw
BRONZE MemberYes, it is beta.
17 December 2022 at 17:20 #37830beojeff
Ah. That must be where the difference is. I guess I’ll just need to stay patient.
17 December 2022 at 17:23 #37831Razlaw
BRONZE MemberThat would explain it.
19 December 2022 at 00:25 #37832Razlaw
BRONZE MemberAnyone in the US using a Dish Hoper with a Theatre? Wondering if the puc works well with it.
19 December 2022 at 13:35 #37833NQVHNWI
FOUNDER MemberDish Hoper?
19 December 2022 at 13:47 #37834Razlaw
BRONZE MemberTypo……Dish Hopper.
19 December 2022 at 13:47 #37835NQVHNWI
FOUNDER MemberAs per the addiction thread – I’ve just installed a Kaleidascape Server so I can get some really high quality video and some mind-blowing sound effects. Truly impressive.
Ive had a number of issues with the Theatre – not just installing the Stratos but also with the Oppo BRP. There is a bug in the BeoApp, BR1, Theatre firmware. It has caused a number of forced factory resets if you do it the “wrong” way.
Im using 3.5mm input jacks connected to the IR-in of each device, PUC A+B Lan to the Theatre.
- When changing the PUC register, the system is sensitive to changes and can lock-up. Names in the BR1 dont get updated.
- Adding the same PUC control to HDMI A and HDMI B locks up. (problem if you have to solve which is A and which is B. (RJ45 Pin 5/6 is A, Pin 7/8 for B)
- Did not realise that the PUC register is extensive in the BeoApp but you cannot scroll. You have to search. Maybe what you want is in the list (DishTV S7090 PVR and Dish Generic DVR are there).
- When applying your PUC configuration, I have found to save lock up of Theatre, BeoApp and BR1, select another source on the BR1, Live TV, then make the PUC change.
- A reboot may be required to initiate the new config.
Will add – the Oppo works great – the Kaleidescape is still not responding but working through that one now.
19 December 2022 at 14:23 #37836GOLD MemberTo wire or not to wire….that is the question ?
Location: Flensborg————Danmark19 December 2022 at 14:33 #37837NQVHNWI
FOUNDER MemberFor me, wired as much as possible.
Interesting in the Theatre and SMI design. There is no room in the theatre for cables – particularly at the base or on the top exit…and there is so much unused room inside the SMI.
19 December 2022 at 16:09 #37838BeoMedia
BRONZE MemberI have also gone for a BeoSound Theatre. I returned the Canton Smart Connect which was absolutely rubbish and a customer support that went into hiding. The shop I bought it from was nice about it all and reported they had now had more complaints as more and more have eARC televisions.
I had a concern that the BeoSound Theatre can only be setup with a smart phone and if B&O was not to continue update the app. However I assume if I keep an old phone with the app installed that should in theory continue to work.
19 December 2022 at 16:17 #37839Sandyb
BRONZE Memberyikes! wired all the way, but that is fairly cramped!
Did you do it yourself?
19 December 2022 at 17:50 #37840yoomy
BRONZE MemberNew Theatre owner here. I have a couple of questions regarding my setup.
Right now I only have the Theatre with 2x6000s as Surround Left and Right. Room Sense automatically disabled the left and right firing speakers of the Theatre. Is that the best option or should I turn these on again as an addition to the 6000s?
The 6000s when setup as surround are really quiet most of the time. I assume that is normal for surround speakers.
If I added Beolab 18 as Front Left and Right, the Theatre would disable its corresponding channels. I could then reassign them both to Center. Does that make sense or will it make things worse?
19 December 2022 at 19:04 #37841Razlaw
BRONZE MemberVery good questions and I have wondered about many of them also. The only one I can give any input on are the 6000s. When I initially set up my Theatre (with BL28s as fronts) I tried 6000s as rears. I also did not hear much from them. I then replaced the 6000 with my pair of Beolab 1s. Huge difference. I now hear sound from them almost constantly. I was surprised how much difference the larger speaker made.
