Home › Forums › General Discussion & Questions › General Discussion & Questions › Neo Radio: Bluetooth, Internet radio solution from Denmark for B&O
Tagged: bluetooth, internet radio, Neo Radio, Neomesteren
- This topic has 2 replies, 3 voices, and was last updated 8 months ago by
Millemis.
31 July 2025 at 09:41 #68059
T.W.GGOLD MemberI’ve just found “Neo Radio” box from NEOMESTEREN in Denmark:
https://neomesteren.dk/en/produkter/neoradio
It’ll give our B&O systems some modern functionality:
– Bluetooth
– Internetradio
– Phono Input
– …Looks pretty interesting and it even allows control via Beo 4 and Beoremote One.
Seems to have a hard wired FM-Transmitter built in which enables you to feed Internetradio directly to the FM antenna input of your Beosound, Beosystem, Beocenter etc.
Unfortunately I couldn’t find any specifications about supported Bluetooth codecs.Does anybody have experiences with this?
31 July 2025 at 18:05 #68078 Severed_hand_of_skywalkerBRONZE MemberHmm interesting. Although I don’t want to have to use a separate app to control my devices. I have a BS9000 and all I did was get a used Essence and hooked that up to it with all the features I need like multiroom, airplay, bluetooth, Spotify and B&O radio. No issues at all.
31 July 2025 at 21:15 #68083 MillemisBRONZE MemberI know this product.
(Btw – it has already been presented on the Beoworld Forum some years ago).
It is developed and is sold as a solution for all those, who wants to maintain their MasterLink setup and – because they have lost the old school analog FM radio – wants to add an internet radio option.
I find it very well described on the website.
Also you can se the BT version (=4.2) there.
I would not be worried about BT….nothing that I use, but it should be sufficient for those, who likes BT streaming.Also there is an option for including a turntable to the mix.
Since the Aux input of the AudioMaster is used for connecting the box, this is via connecting this to the box.In my opinion a clever solution….
……which unfortunately comes a bit too late for those of us, who already have migrated to a NL-based solution.MM
